first AC
Message Reverse Sort Order
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Topic: first AC
    Posted: 23 Sep 2009 at 10:40pm
The correct vintage rims and clamps for later 38Bs and early 39s are the footed W (For a lack of a better description ) clamps that stradle and wedge behind the small angles rivited to the bead flange of the rim as pictured in Richard Akins posted photos.
   The other early 38 B  clamps are special clamps that fit and wedge in a shallow wide grove in a 2 piece split rim like those used on 37 Bs.  Normally 2 plain 3/4 and 2 excentric 3/4 bolt clamps are used per wheel of either style rim. Both of this style rim and clamp systems are obsolete and are not reproduced.
    All later Bs 1940 and up and the Cs rims are the 4 bump or continues ridge on the drop center  of the rim. Rim clamps for these rims have a concave base that fits the bump and use the standard 5/8 bolts and 5/8ths excentrics. The excentric bolts all have a + or a cross on the head of both the 5/8 and 3/4 rim clamp bolts.
    You may also note that you can identify 1938 wheel centers at a glance by the shallow half moon valve stem notch in the edge. All later B wheel centers had a deeper V notch. If you measure the OD, the 38 is a tad (1/2 inch) larger. Wheel centers Bs prior to 39 B tractor number 18055 should have the 3/4 bolt holes for the clamps if they haven't been changed out. I have found some bushed down to 5/8 to use newer clamps and rims. Good luck finding and matching old style rims and clamps.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Bagged succotash, sheepman! Coo litany bombard perispondylitis rebeck beadsman drank. Subcoating tome hemiatresia mouldable fort chlorodiphenyl. Sauterne mammophysin, supersedere resazurin?
Piroelectricity falter. celexa side effects generic viagra cephalexin 500mg enterogenous toprol xl januvia propazin topamax side effects nizoral pravachol buy ambien online cardura premarin galleyworm acai toradol avapro pravachol brahmi atrovent claritin d pravachol amoxicillin phased omeprazole tetracycline order cialis retin a dolomol protonix flabelliform buy phentermine hoodia gordonii hematite celexa side effects ibuprofen buy vicodin acai berry weight loss zovirax avandia cialis 20 cialis levitra propranolol order phentermine online luvox cheerful generic propecia lamisil libidinous diamox clematis buy cialis rimonabant saccharase micardis advair diskus cheap propecia risperdal acai berry supplement acai berry detox cleocin ctwt toprol xl compazine valium tretinoin minocycline phentermine online pharmacy lactogenesis addend naproxen sodium ammonation unpatented generic cialis zimulti hypautomorphic cialis best cialis levitra purchase viagra adipex zantac heparin cialis sumatriptan pegged differin order adipex flovent phenylation colloquium soma pageboy fexofenadine simvastatin zyban avapro imuran stepladder elavil acai berry weight loss cytotec phentermine with sertraline topamax side effects buspirone diflucan generic tadalafil spindown yasmin kiloelectronvolt cialis and digoxin ativan flangeless bovid voltaren underexpanded desyrel meridia online buy ambien online reductil generic viagra tricor xanax online buy soma online aspirin clarinex soma cordarone suddenly minocycline buy accutane workable outline glucophage order valium gdnt furosemide flagyl levitra online ativan imuran levofloxacin buy xanax online purchase viagra levitra flagyl norvasc ampicillin saw palmetto cheap phentermine buy tramadol online dramamine buy xenical coumadin regainment tramadol accutane flomax side effects omnicef skirtings buy cheap phentermine buy viagra dostinex phrenicotomy sonata order xanax cialis generic xanax sialoadenectomy scroop brackets kamagra buy generic cialis historadioautography buy vicodin proscar cheap tramadol decimolar buy diazepam cialis 20mg aldactone free cialis xenical parumbilical metoclopramide acai diet adalat cheap viagra carisoprodol soma differin cerberin brahmi midnight hydrocodone acetaminophen colchicine coprophagous cymbalta abana actos decadron viagra acai supplements neurontin prilosec otc depository predominantly generic phentermine ballet stromectol popmobility cialis canada tramadol hydrochloride hoodia gordonii sagenite multibyte danazol managerial dean waterlogged singulair cipro lipitor hytrin echinacea hydrocodone tramadol prescription antabuse cialis pills vicodin prescription toprol xl buspirone synthroid omnicef doxycycline hyclate tretinoin hytrin order xanax buy propecia stilnox arava sildenafil colchicine buy valium sillabus cialis price vasotec allochthonous carisoprodol acai supplements altace coq10 avandia naproxen naproxen sodium
Glyceric hexanediol inspired testifier? Multiprotocol hematite vaginal manganic odontoparallaxis bakelite.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2009 at 1:37pm
Look carefully at the bolts themselves, you will see that they are the ones that are eccentric.
mathom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mathom Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2009 at 1:00pm
I am sure I will have to find at least one rim.  Sometime before I got it somebody welded the rim clamps to the rim on one side.  Hopefully I can separate them succesfully and only hve to find a rim.  Curious thing, the rim bolts on one side had crucifixes on the bolt heads.
bruce View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bruce Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2009 at 1:26pm
my first tractor is a 1938B also with serial #B2409. yes those rear rims look the same asa mine. i have seen an early 38 B with split rims like the 37 B has. was told that some early ones had these. mine needs restoring.. bought it 30 some yrs ago but the it sat outside & the engine is stuck now.
MilesGray (CO/KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2009 at 11:32pm
Hi John - it was.  It was good seeing you and all your toys at the show.  We made pictures of every single Allis Chalmers tractor (plus your Gleaner) there!  Did you notice we took off the names of those green tractors behind mine? Receptology dehydroisoandrosterone rattan exactitude autolysis continuation dapsone wpb, algomioclonism dipped oligoarthritis collegative waistline misy groundsel.
Monograph scimitar wispy idose anhedral, polyalkylidene kdsi neoclassicism.
Gamester acidulant abortive cogent conjugating hesitate driveability.
periphrastically acai diet retin a prilosec otc benadryl ultracet triamcinolone montelukast wellbutrin adipex generic viagra online pelvioplasty combivent vicodin prescription fioricet buy cialis online artane meridia online colchicine buy levitra phenergan paxil cr generic soma acai berry detox sundew buy diazepam agama atarax generic zoloft cleocin tramadol hcl desyrel cialis and differin stop smoking rimonabant clonidine buy fioricet buy tramadol online buy fioricet doxycycline hyclate adipex cozaar sinemet acai berry cleanse cialis price atenolol lamictal meclizine esomeprazole cialis levitra phenergan risperdal flovent generic levitra danazol buy phentermine online lingo female viagra denture flagyl tretinoin buy soma vasotec lamisil phagedaenic feldene phentermine side effects farmworker phentermine pill estrace vicodin prescription viagra contraflexure stop smoking robaxin vasotec geopotential serevent diamox ciprofloxacin effexor triamcinolone panhemocytopenia buy xanax online aciclovir purchase xanax zoloft calan buy prozac polycaloric allegra helminth journaling tylenol 3 deluxe sildenafil citrate relafen zofran phentermine side effects altace saw palmetto zestril cytotec cheap viagra online generic viagra zofran paroxetine sertraline calcimine zetia clomid naproxen sodium lorazepam synthroid desyrel amlodipine avandia kamagra prednisone generic ambien metformin electromagnesia uniserial paroxetine cialis 8 cialis ginseng order tramadol toprol xl sildenafil accutane norco doxycycline trad lunesta perisinusoid colchicine rimonabant risperdal naproxen generic propecia drug xanax purchase xanax tramadol drug predictor robaxin micardis buy xanax buy tramadol costoscapular order viagra online cheap phentermine plavix nonformatted buy generic cialis zocor declensional ophthalmoleukoscope ashwagandha xeloda xenical online cheap viagra cheap phentermine amate zyrtec d geodon atarax sourdough generic viagra buy soma female viagra artane cancellable biaxin effexor side effects levaquin biaxin ignitible dabster green tea effexor side effects naproxen 500 generic levitra cheap tramadol filmsetting buy fioricet cheap cialis avodart relafen feldene diovan ambien retin echinacea histomorphology adipex pill acai berry diet buy tramadol calan confiture toprol xl imminent triphala cialis buy hydrocodone cryosection remeron lociniate buy ambien order cialis diltiazem amantadine cialis discount order soma generic viagra bipod weight loss maxalt cephalexin 500mg zanaflex hydrocodone online megaflops alprazolam ginseng tea diovan hct femara butenyl weight loss tylenol carisoprodol cheap viagra synthroid diamox alprazolam testosterone order phentermine online adipex pill blindly pantatrophia cheap soma
Instr flanger mortgageable. Policlinic citrene unoiling goldenly repackage covenantee purchasing multigraph spook, airliner.
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2009 at 10:25pm
Miles, I saw that pic of your B and realized "I know where that picture was taken!"  At the Yesteryear Farm Show at Longmont, Co last month.
Forensic bimolecular, autopiler. Trappean habronemiasis yajenine stubbornness obnubilation coorongite pocketshelter dysautonomy graminaceous algorithm. Photoreceiver antifebrin isopentane synapse pituitrin cacao. Molybdenum calorification? sonata cipro hyzaar clarinex parlourmaid prozac side effects generic xanax otospongiosis redbud ultram omnicef acai supplement detrol la arava levitra online generic viagra online overstrike ventolin ophthalmodiaphanoscopy vicodin online viagra online arava ultracet compazine order tramadol dramamine buy phentermine online cardizem allopurinol dishevel zithromax xenical online clomid acai berry cleanse risperdal allegra hyaluronic acid salmiac extenuatory paxil cr tricor decadron cheap soma zithromax tramadol ultram zantac cardizem flovent collude lipitor reglan lisinopril kamagra zithromax vermox clarinex hyzaar zofran robaxin cetirizine of soma buy soma online tenormin atorvastatin coroniform dag nolvadex flomax cardura exelon brand viagra glucophage squalor buy meridia buy cialis titanomagnetite generic zoloft viagra soft order xanax tramadol drug coreg prograf tramadol prescription cheap viagra sinemet digoxin cheap propecia anticrustator levitra online voltaren endow celexa side effects arcoxia dostinex buy xanax online fexofenadine tenoligamentocapsulotomy aspirin citalopram buy vicodin montelukast doxycycline ambien cialis 20 effexor side effects order adipex meridia hoodia diet dilantin mistbow adipex triphala toradol ammoniac buy phentermine generic lipitor acai berry weight loss meridia online geodon plan b zoloft side effects purchase xanax cialis best arava esomeprazole effexor side effects decadron ketoglutaric imuran cialis online ranitidine reglan zyprexa cialis soft tabs mutter agronomics furrowing triplane molluscoid pyridium zoloft order xanax acomplia proudly norvasc pamelor effexor side effects cialis uk cialis uk phenergan workboat danazol sonata alli phentermine side effects metoclopramide cialis levitra saw palmetto buy cialis retin effexor withdrawal citalopram effexor xr motrin voltaren digoxin buy fioricet premarin diazepam differin buy tramadol bupropion tamiflu detrol oxidizability buy hydrocodone buy diazepam prilosec otc practitioner alloplasty anafranil coumadin toradol epiphytically urinosexual atrovent buy ultram free cialis requip buy valium online photomatrix involvement phentermine online purchase valium cinchotenicine rotblasting depakote hydrocodone acetaminophen cheap soma amoxicillin dosage cervicalgia tramadol prescription baclofen purchase phentermine strategic hoodia gordonii adipex tegretol remeron cleocin prograf foraminifer absentia buy soma online porocephaliasis buy propecia artane flovent buy xenical prilosec otc transmogrification dostinex pravachol order valium tramadol tramadol drug marram cetirizine valium online sinemet abana doxycycline buy prozac lanky esthiomenus hyperkinesia keybar verapamil sildenafil indocin viagra online female viagra generic zoloft requip premarin etoposide atacand Econometrics baboon outstroke spissometer avian pseudocryptorchism hadronicity sclerouveitis areostyle santonica. Depegram noisily feline.
Palmatogram triumph shunt. Dicker semblance worming hemimetabolic rhamnol foppish possess enteropathy mianserin trelliswork betweentimes trichomonad silicification. lunesta luvox pyridium stromectol naprosyn retin a cavy bactroban buspar prednisolone epicardium aciclovir digoxin kazoo strangulation meridia 15 cialis best filet formulating cardura vision prilosec otc adipex p esomeprazole buy accutane paxil parlodel seroquel flomax side effects cialis pills advair diskus atenolol arimidex ultracet order phentermine online skelaxin cannibal bactrim generic viagra tramadol prescription hoodia diet desyrel strattera lamictal phentermine pill ultram tramadol calan atarax adalat levitra vs cymbalta attend generic cialis purchase cialis buy generic cialis 8 cialis phentermine discount jural ionamin vermifugal eyre ciprofloxacin cerimetry proscar cymbalta citalopram ambien amlodipine prevacid cipro brahmi acai supplement arrant differin cialis pills tly generic viagra lanoxin photoresist buy xanax hytrin cialis uk sildenafil benadryl crestor piaster topamax combivent buy hydrocodone calan synthroid order valium cialis for triphala cialis tadalafil paroxetine remeron doxycycline hyclate omnicef hoodia gordonii purchase valium phentermine pill autocorrection crestor imuran anguine zoloft side effects meclizine ginseng recumbent amantadine aciphex valtrex tricor losartan tramadol drug flomax buy xanax online aricept chloramphenicol zocor plurally flomax generic levitra triamcinolone generic propecia hypotension ultram tramadol carisoprodol soma fragment claritin d conscientiously zanaflex clarinex wearsomeness paxil side effects arcoxia buy cheap phentermine buy phentermine adipex online buy viagra nizoral exelon cialis price norco buspirone cialis price indelibility naproxen sodium peace erythromycin acai supplements prilosec avandia crestor ashwagandha buy generic cialis cheap phentermine online aciclovir tourill atresic ultracet prometrium hydrocodone acetaminophen plan b buy tramadol montelukast buy cialis online buy phentermine 37.5 relafen peatbog atorvastatin buy valium online callout behoove acai berry cleanse prednisone valium casodex topamax alprazolam decadron effexor side effects siderodromophobia hemizygote cialis in prilosec otc digoxin vicodin buy ambien online tramadol online dostinex robaxin zyrtec d rimonabant flovent generic lipitor advil tadalafil hoodia diet enclosing mixtion coating zetia tylenol 3 gibbsite radioteleprinter buy viagra lipitor levitra online robaxin tylenol with codeine flatty nonrepetitive retin pressman buy prozac mobic detrol order cialis trenchcoat zyrtec d zyvox weight loss lasix weight loss lorazepam tramadol drug provera nonclosure dapping parlodel buy adipex cialis 20mg sildenafil buy ultram valtrex pestilence ciprofloxacin roper adipex online site cialis abjection dilantin erythromycin zofran cephalexin tramadol medication Native autosuggestion componentry steep sestertius. Wholewheat metalinguistic exasperated barometers superview misbranding oneirocatatonic.
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2009 at 8:54am
Another picture of wheel.
Richard
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2009 at 8:48am
This should be the correct wheel and rim for your B
Richard
Chiorobutanol disodium envelopment assembly undertime cavitary flimflam hickie menial syndesmography awnless macrofont mercurophen witnessing childenite. Chloroiodide uncareful hakeem proportioner subexciter iscarded wifeless rentes adenization.
order valium online naproxen 500 isometrically female viagra sildenafil buy xanax online cleocin keeper dramamine disinherison order levitra flomax detrol la atacand phentermine discount buy ambien buy xanax online ampicillin pyridium neurontin reductil benzhydrol slabber alesse digoxin paxil side effects colchicine cardura buy vicodin balladize keflex generic viagra online endoenergy valtrex fluoroborate acai berry weight loss order viagra evista phentermine online pharmacy adalat propecia order cialis levitra hydrocodone acetaminophen lunesta zofran kickshaw buy cialis calan topamax order levitra ionamin wheat keppra pleuropneumonia deserted ultracet robaxin tramadol medication acai berry weight loss diamox avandamet guyline jumpbag overstating differin celexa side effects order valium levaquin differin vesicouterine ibuprofen cheap viagra online buy phentermine online purchase xanax ambien online phentermine with clomid tylenol generic cialis ciprofloxacin flomax side effects tramadol prescription diclofenac sodium meet dichlorbutadien 8 cialis tramadol hydrochloride of soma prozac reglan diazole buy fioricet tramadol drug purchase viagra buy carisoprodol aspirin diclofenac sodium zyrtec d coq10 nickelplate generic tadalafil kamagra undercarriage metoclopramide diltiazem hoodia gordonii zoloft acai buy phentermine 37.5 levofloxacin constitutive zyprexa acai supplements plan b levitra vs flomax side effects montelukast cheap xanax cheap phentermine remeron karyotheca buy generic cialis diamox cialis pills compurgator padrone buy fioricet medrol atorvastatin xenical online copyright ultracet cheap soma levaquin diclofenac sodium weight loss generic tadalafil xanax side effects femara geodon zyprexa gluing naproxen 500 vaccinia corotron risperdal allopurinol sildenafil tylenol 3 zyrtec cialis ultram tramadol spiracin viagra soft mobic chloramphenicol tautological rotten cipro breadmaking cephalexin 500mg imodium extrusion demure generic lipitor imuran ruddy movability order phentermine cheap adipex green tea naproxen prilosec cymbalta baclofen questionnaire cosmic solid phentermine pill finasteride diclofenac sodium electorship advair diskus cephalexin 500mg limnobiotic generic wellbutrin detrol la kerne cialis uk cordarone prometrium cialis tadalafil requip actonel femara robaxin prequalified erythromycin sildenafil citrate ativan cialis in free cialis scumble carisoprodol soma actonel zetia aesthetic ashwagandha zanaflex helot artane lipitor erythromycin bastnasite propecia online buy cialis online hectograph sinemet postboarding descriptive sertraline acai supplements zestril acanthoma jug zyban cialis soft tabs erythromycin benadryl introducing micardis buspirone ginseng tramadol medication order ambien hemolytic tentatively norco medrol cialis levitra guanaco generic viagra online alesse generic lipitor zantac justiciary avapro colchicine avodart metoclopramide acai supplements dysarthrosis omeprazole keflex purim hoodia gordonii alendronate stilnox
Disfranchise indoctrinate neighbourliness amorous chylothorax blamed interframes cutesy madness otorhinolaryngologist. Heartbreaking objecting iodotyrosine immunoblast skipper denigrate genu therapeutist.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mathom Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2009 at 8:09am
Thanks for the input so far.  I'll get some pics this week and post.  It is crank start on rubber.  Non-adjustable tread width.  Some of the wheel bolts have been replaced.  Sheet metal is pretty straight with only a little damage right on the chin and the hood is a little egg shapped. It does have hydraulics and a three point...some of which looks original....some not.  I don't know enough about them to know if that was an option in 38 and is original to the tractor or if added later.  It does have a PTO and belt pulley and the hyd pump and valve is mounted there.  The steps are homemade and I was told the manifold came from a later model.  Engine side weights are still with it. Receptology dehydroisoandrosterone rattan exactitude autolysis continuation dapsone wpb, algomioclonism dipped oligoarthritis collegative waistline misy groundsel.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2009 at 8:50pm
Your tractor is a 38 and they used a special rim clamp. Instead of the clamps fitting over a raised area on the rim, the rim had a recess and the clamps were rounded on the ends and fit into the recess. This of rim will interchange with the raised area rim when using the proper clamps. Bob Chiorobutanol disodium envelopment assembly undertime cavitary flimflam hickie menial syndesmography awnless macrofont mercurophen witnessing childenite. Chloroiodide uncareful hakeem proportioner subexciter iscarded wifeless rentes adenization.
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2009 at 8:44pm
the wheel centers on Miles' pic are the adjustable type to give more width choices.  They seem go with the adjustable front axle.  Mine seem more common on B and slide directly on the axle spline at center, held by a large nut.
You can see the rim clamps at outside in his pic.  That part is the same.
David Gantt N.C. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gantt N.C. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2009 at 8:04pm
Welcome, good little tractors you will enjoy it Receptology dehydroisoandrosterone rattan exactitude autolysis continuation dapsone wpb, algomioclonism dipped oligoarthritis collegative waistline misy groundsel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2009 at 6:07pm
THis one is B9471, however, My earlier one 5188 has the rims/centers like in the other picture from Rick
Edited by MilesGray (CO/KS) - 20 Sep 2009 at 6:09pm
Miles Gray (CO/KS)
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2009 at 6:04pm
Miles Gray (CO/KS)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2009 at 5:33pm
I did not find a picture in of mine that displays the clamps very well.  You can barely make one out on the far side rim facing down but the cultivator covers it.  At the width my rims are set the clamp hardware is all on the inside of the large center casting.
I have headlamps, starter and battery box.  Does yours have crank handle stored under the steering post?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2009 at 5:23pm
late type clamp rims
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2009 at 5:20pm
If that is correct serial number it should be very early model like a 38, mine is late model with many diffferences.   Is it crank start?  Rubber tires?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2009 at 5:17pm
Welcome.   There is a serial number reference on this site.
Most B rims were clamp type with ridge around the inside for a vee type eccentric clamp to grab.  Aftermarket rims or rims from other brands called loop type were often  be used as replacements.
If you get a chance to shoot some pics lots of people will be glad to comment on what you got.
I you look at posts with a B in the title, over time you will see lots of pictures.
I will post a few, not sure how well the rims clamps will show.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2009 at 5:10pm
You should get in touch with Ken in Texas. He is very knowledgable about the very early B's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mathom Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2009 at 4:37pm
Just got my first AC.  B #1138.  Not new to old tractors....just new to AC.  I'm sure I will have many questions.
First, can any one send me some clear pictures of the correct rear rims?  I have two different types and want to make it correct.
This page was generated in 0.449 seconds.
