7000 PD
Bob C IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Topic: 7000 PD
    Posted: 03 Aug 2013 at 9:39am
How is a Oliver running a multipower in my class and will a 7000 pd hold up with some modification?????
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2013 at 10:15am
don't understand question - there is a 7000 tractor and a 7010-7080 tractor.
I guess the oliver (read 9100 series Agco as some are the same) came with it ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2013 at 1:27pm
In my pulling group there is a Oliver 1755 and he shifts it... My question is what is the difference in clutch packs on thAt tractor and mine? He also runs a cummins.. MINE IS A 1980 7000 BLACK BELLY
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2013 at 3:39pm
What gear are you trying to pull in ???     What gear do you think you want to pull in ???  You have a terrible change in gear ratios from 3rd to 4th gear on the transmission.....like from 7.5 mph (3rd)  to 15 mph(4th) in direct range. The Oliver designed and built "over/under/direct" unit is self-contained and pretty darn durable. The Oliver also has 6 transmission selections to choose from and you have four.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2013 at 3:50pm
Stayin in 4th but could use some split gears... 4 low 4 int 4 high depending on track and sled conditions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2013 at 4:20pm
I don't know if one could ever modify that A-C clutch to do that. So, it holds OK now in 4th LOW ??...I thought you eliminated it completely and only had LOW range.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2013 at 6:40pm
I am locked in 4 intermediate but a few extra gears would be nice . I was only askin because of the Oliver ... Just wondered how its clutches worked
Larry W. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry W. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2013 at 6:51pm
Bob, could you send me your phone number on a pm message, would like to talk to you, thanks.
