clogged fuel injector hd4
blackbirdstud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blackbirdstud Quote  Post ReplyReply Direct Link To This Post Topic: clogged fuel injector hd4
    Posted: 02 Aug 2013 at 2:29pm
I ran my dozer low on fuel but not out and was using in up and down a steep hill.. I think I shook up what was at the bottom of the tank and clogged my fuel filter so I chanegd it bled the system and got the air out, but I think I have one of my injectors is a little clogged as uit seems like mid throttle is sputters a little. it never use to do that..   Can I take the in jectors off soak them in karosene or somethign to clean them out, has anyone else had this problem? any help would be great.. thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote blackbirdstud Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2013 at 2:46pm
where can I buy new injectors if possible?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2013 at 7:28pm
any reputable Injection pump service provider can clean, inspect and repair if necessary. new, if available would most likely be burning good money.
Post Options Post Options   Thanks (0) Thanks(0)   Quote blackbirdstud Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2013 at 6:01am
oh ok thats good advice thank you
This page was generated in 0.891 seconds.
