Dave's AO
Doug R MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doug R MN Quote  Post ReplyReply Direct Link To This Post Topic: Dave's AO
    Posted: 30 Jan 2010 at 2:01pm
Dave Furguson's AO on the sawmill at the Little Log House show at Hastings MN in 2006. Picture testing /practice.
Doug
Kipn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kipn Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 2:28pm
I thought that you should put a twist into a belt? For what reason, I don't know.
1961 H3
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 3:02pm
I may be wrong but the twist changes direction of rotation.
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 3:03pm
I think it depends on which way the pulley on the unit being powered needs to go. Put a twist into the belt if it needs to go the opposite direction of the pulley on the tractor. I THINK!!! sometime correct me if I'm wrong or if theres another reason.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 3:26pm
A twist in the belt reverses rotation of the driven pulley and when I hooked my CA up to the belt driven Dyno at our show several years ago I believe it took about 5hp to turn the belt at high idle because of the friction of the 2 sides rubbing together.
MikeB (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeB (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 4:02pm
 http://www.youtube.com/watch?v=f3MYAmEVtoo
Here is a video of that amazing tractor on the PTO dyno at Hutchison. Warning you will not be able to watch this video just once. Notice the guy running around with the heat gun checking exhaust temperatures. If I can remember right it put out over 70 horses.
Link not working type "AO dyno" when you get the you tube site.
Edited by MikeB (SD) - 30 Jan 2010 at 4:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doug R MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 4:19pm
 There was a twist in the belt but you are only seeing about 1/4 of it. It was about 45' long.
Doug
