I-40 info and decal needed
BradinNC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BradinNC Quote  Post ReplyReply Direct Link To This Post Topic: I-40 info and decal needed
    Posted: 30 Jan 2010 at 8:32am
I'm looking for the decals that go on the side of the boom for the I-40.I also need the lengths for the indicator tube and rod that show the tilt on the bucket.
Thanks in advance.
andytutd21 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote andytutd21 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 9:57am
I had to go look at my I-40, I have the clamp but no tubes. I would think that you could measure the distance with bucket level and make your own tubes. I haven't seen the decals but would like a set also. These are pretty handy little tractors.
1984 8070 ps fwa, 1969 D-21, 1965 D-21(puller), 1968 190 XT, WD-45, Gleaner L, I-40 loader, TS200 Pan, AD-3 Road Grader, 918 Backhoe, HD-4 6 way, HD-4 loader, HD-7G, HD-11, HD-21
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 6:50pm
Have you tried Lyle Wacker?
Post Options Post Options   Thanks (0) Thanks(0)   Quote BradinNC Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2010 at 7:54am
Not recently.
I tried him a year ago with no luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2010 at 11:39am
If Lyle doesn't make it, I would take it to one of those Signs by Tomorrow type stores, show them what you want, most all of them have computerized vinyl cutters, you just have to figure out a font, size, and design.  I'm sure it'll cost more than Lyle's stuff, but custom always costs more.
pbqc3803 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pbqc3803 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2010 at 10:58pm
Hello I have a I-40 I would like to know if there is a tractor the same as the I-40 for parts if not then where can I find parts. I would like to fix it up. I need parts like exhaust manifold, front RH spindle, radiator and rear wheel locks. Thank for all your help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 5:06am
Welcome to the site, Pbqc, you need to find a junked D-10/12, they are the ag tractors that the I-40/400 are based on.  Exhaust manifold is very similar to a D-14, as they use the same motor.  A D-14 manifold will put the muffler out about 1 to 1-1/2 inches from where the original muffler was.  Rear wheel locks are common throughout D10 to d 17, I think.  Good luck.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 6:41am
The I40 is a AC D10 Series III with heavy front axle, power steering, heavy radiator shroud, 8-bolt rear hubs instead of 6.  I may have missed some items but if you are looking for other parts, also look at the D10 III, D12 III as a source.
pineyjd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pineyjd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 7:02am
There are sponsors of site that have the manifolds,just found my  gas gauge at sandy lake ( ask for Brenda) after 7 month search,they have D10/D12 parts, I do not have rod on my I 40 bucket,but you could make one.
Hardest part to find is fenders
I am redoing my machine this summer when I get home from fishing in florida,
if you need info on part # there are I 40 owners with part list/book & I have some books
Post Options Post Options   Thanks (0) Thanks(0)   Quote pbqc3803 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 10:18am
I would like to thank all you for your help. I have been looking for parts but I just did not have all the info to find them. Thank to you I can move forward. I will try to post some pic as I get it fix up. This has made my day. Thank
Paul B
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 12:37pm
Joe, isn't an I 40 a series II, and I 400 series III?
split51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote split51 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 1:36pm
If someone can get me the dimensions of the decal and let me know what colors are on it, I can duplicate it. I own a sign shop and have a vinyl cutter and a digital printer.
Edited by split51 - 20 Feb 2010 at 1:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote BradinNC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 4:11pm
The I40 and series 3 d10 are also the same. I'm about finished restoring mine.
I had to paint it orange instead of yellow. I'll post some pics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pbqc3803 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2010 at 6:49pm
Can you put a 3 point on an I-40 and if so can you hook up a brush hog on it. It looks like I can pull a cover plate off. I just have not done it yet I have to remove the backhoe and I'm not ready to do that yet. Thank for all the info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2010 at 6:54pm
It can be done, but if it does not have the pump and shaft to run it, you are looking at a major expense, for the parts, IF you can find them!
easygoin4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote easygoin4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2010 at 11:09pm
If you still need the tube and rod length for the loader - please email me and I will go measure mine.  I have an all stock I-40 with Allis loader and backhoe. Sorry it does not have the decal your looking for - but I had someone make me the front I-40 for each side of the radiator cover.
easygoin4@yahoo.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote pbqc3803 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2010 at 10:12pm
I'm looking to get some manuals for my I 40 I have the backhoe manual. How many Manuals are there for the I 40 does anyone know if so can you let me know so I can try to buy them I think there is three one for parts and the other for technical and one for operations. Thank for all your help
Paul B
Post Options Post Options   Thanks (0) Thanks(0)   Quote easygoin4 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 6:22am
I have all 5 manuals- loader parts, backhoe parts, operators and tractor.
I will make copies and send to you if you would like- may take me a week or so to pull together.
Or I can scan and send you a PDF via the computer.
If interested send me email, also I would like to see pics of your tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pineyjd Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 6:55am
Where is the ind rod mounted ??,L have never seen one on a machine.
Jack
Post Options Post Options   Thanks (0) Thanks(0)   Quote BradinNC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 9:38am
Here is a copy of the sales lit.
Brad
Post Options Post Options   Thanks (0) Thanks(0)   Quote BradinNC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 9:41am
Chris,
Will you send me the dimensions for the indicator rod when you get a chance?
Thanks,
Brad
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 10:12am
Could you post a picture of the dash of the I-40? My D-10 has a wierd dash...I want to see if it is the same as the I-40
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote easygoin4 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 10:19am
I have posted it just last nite in another post- llok for I-40 dash topic..
Post Options Post Options   Thanks (0) Thanks(0)   Quote pineyjd Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2010 at 5:54am
Brad,
Do you have any parts #/ picture  of f/r shuttle,I don't have that in my parts book ?
going to rebuild  transmission this summer
thank's
Jack
Post Options Post Options   Thanks (0) Thanks(0)   Quote BradinNC Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2010 at 8:41am
Jack,
I got the picture and parts list from Sandy Lake. They faxed it to me and told me to circle what I needed. They are great people to do businees with. I have rebuilt one reverser and have another tore apart right now. Let me know if there is a certain part that you need a pic of. The first one I rebuilt had a busted shift fork. I had to make one on the milling machine since they are no longer available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pineyjd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 5:33am
Brad
Thank's for info,just bought gas gage (oem ) from sandy lake,fellow I bought mach from could never find one for 12 year's
I am going to take mach apart this summer for repaint/rebuild
have most of the parts,except plate by rh steering box
Post Options Post Options   Thanks (0) Thanks(0)   Quote easygoin4 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 7:25pm
Brad,
Just measured the indicator rod for my Loader.
Tube is 26 1/2" long and the Rod is overall 44" includes 1" of threads that go thru mounting bracket on loader.
Hope this helps,
Post Options Post Options   Thanks (0) Thanks(0)   Quote BradinNC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2010 at 6:22am
Thanks for the help Chris.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pineyjd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2010 at 3:30am
Brad,
Where are you in NC ?? I go to monroe on my trip home from florida.
My brother lives out by a equipment dealer (ironmam)
Post Options Post Options   Thanks (0) Thanks(0)   Quote BradinNC Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2010 at 7:43am
I live south of Greensboro.
Will you be traveling up I-85?
This page was generated in 0.184 seconds.
