Plowing Question
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Topic: Plowing Question
    Posted: 29 Jan 2010 at 9:08pm
I was looking at a book of mine on Caterpillar, there is a copy of an old add in there for Best Tractor from the early 1900's.  It shows a drawing of a Best 50 (50 hp) steam tractor pulling 16 10" plows.  How come that 50hp and a D17 is not the same?  Is it the weight, wheels or something else?
Did they not rate HP the same back then?
SCPAAndy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SCPAAndy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2010 at 9:21pm
tons of variables but mostly final ratio of the transmission and rear end once power gets to the ground plus depth of plow, soil etc......
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2010 at 9:42pm
That was a great question!!! I want to learn more also. Ryan
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2010 at 9:50pm
weight and tracks.  Its the same reason my HD-3 will skid logs out of the woods that I couldnt pull with my 160.
160 CA 920diesel 5020 HD-3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2010 at 9:52pm
Steam power is a super force. The ratio of power is formidable. I can't remember but 1 quart of steam under pressure, turns to I think 18,000 once it is out of the cylinder in the air. Almost infinite power in the right conditions. I am sure that if dynoed today, it would present more than 50 HP. Tracy Martin
Edited by Tracy Martin TN - 29 Jan 2010 at 9:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2010 at 10:01pm
Ground Speed,Weight,Size of Plow(12"14"16"18")angle of plow,type of soil.Put a 50 HP Allis Engine in a Crawler it could do the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2010 at 10:05pm
This was not a crawler, it was a steam tractor.  Also said it was pilling the plow at 3 mph, Fresno County Ca.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 7:39am
Steam power rateing was before  Nebraska testing and was concidered " nominal " or in this case what about 50 horses could pull.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 7:51am
It is hard to rate a steam engine, the pressure varies, the rate of delivery varies, a great deal of variables along with gear train etc.
Steam expands at 1300-1, for every 1 pound of water by volume there is a 1300 times that area for 1 pound steam, a really hot boiler can deliver a lot of steam by volume while a cooler one will deliver 'enough'.
I work in a steam power station, sorry in advance if I get too technical at times.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 7:52am
My own question:
I have a ageing 180 dsl, what would be a good sized disc and will discing a field ready it enough for planting from being pasture?
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 8:31am
 I'm with you on this one.
Don
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 1:11pm
Remember to that power required plow to a point goes up exponentially as speed is increased, ie a 100 hp tractor cant necessarily plow twice as fast as a 50 hp tractor.
Weight makes a huge difference in traction.
Also, as some one mentioned, a horse power is not always a horse power.  The difference in work that an 1hp electric motor/gas motor/diesel motor/steam/horse are all different.  Old hp ratings were more of a continous all day type rating.  For example.  A mid size draft horse can pull 1 10" bottom most of the day, but for very short times can put out enough momentum/tractive power to pull loads that only a 40 hp tractor can put out.  But again short burst.
Also most steam engines and early combustion engines had huge flywheels which could store an amazing amount of reserve power for those hard spots.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 1:21pm
The torque produced by a steam engine is higher than even a diesel engine too isn't it? As long as the valve is open and steam is pressing on the piston, it is producing more torque right? Then there is the return stroke that produces power too instead of only one power stroke per 2 revolutions of the crank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 1:38pm
Can be Brian, depends all on the engine.  Some are single acting(steam in one direction only, others(most larger ones) are double acting, steam on both sides of piston.  Steam can have tremendous power at start up, more than sometimes the mechanisms can take if you are not careful. Steam locomotives where hard to control because you could easily slip the wheels, typically wouldn't/couldn't put full power down until up to a pretty good clip because of this.
