Ford 4000 gasoline
Charlie (NC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie (NC) Quote  Post ReplyReply Direct Link To This Post Topic: Ford 4000 gasoline
    Posted: 12 Jul 2013 at 11:50am
Does anyone know what kind of Carb is on a 72 model
Ford 4000 gasoline tractor? I think it's the newer engine
and not the old one from the N model and hundreds models.
I need to go about 30 miles one way to check on a problem
my friend is having and would like to know what I'm dealing
with before I get there.
TL12A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TL12A Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2013 at 12:10pm
Hi, I h ave a 1970 Ford 4400, 3 cyl gas with aHolly Carb. HTH. Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2013 at 12:17pm
Holley.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2013 at 3:02pm
I have a 4000 Holley Carb I don't need
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie (NC) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2013 at 10:00pm
Thanks guys, that is what I thought from what I could find online.
I haven't looked at the tractor yet. The owner says it will run for a while, then start missing, spitting and sputtering and pulling the choke out helps so I figure it's trash or water in the carb.
I'm not sure I want to mess with that Holley. I know Zenith and M-S carbs inside out but I hear that Holley is a bit tricky.
This page was generated in 0.219 seconds.
