D 10 III Steering gear box wanted
Joe/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe/NC Quote  Post ReplyReply Direct Link To This Post Topic: D 10 III Steering gear box wanted
    Posted: 28 Jan 2010 at 9:16pm
I am still looking for a Ross gear box, posted request on here about 6 mos ago and still looking. Hope someone may have one for sale now. Thanks!
Jamie NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie NC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 9:31pm
Joe, I belive that you know a guy by the name of Mitchell barefoot. Call him I think he knows of a part tractor D10. I looked at it a year ago when I was down you way to vist with mitchell.
Allis tractor puller CA WC WD D17
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2010 at 9:33am
Joe
Can your gearbox be rebuilt? The one on my D12 rehab had lost the bearing balls on the worm gear shaft, the outer seal on the output shaft and the seal on the steering column. I was able to match up the bearing balls from #605 sealed bearings (busted open the sealed bearings to obtain the balls). The ball races may be able to be matched up with other manufatures ball races, mine were usable, so did not research replacements. The output shaft seal is still available from AGCO. A friend (with a small lathe) turned a new steering column bushing out of FRP plastic for me. Made my own cover gasket out of gasket sheet stock and small ballpeen hammer.
