Look what WC came to live on my farm
NC Bruce View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NC Bruce Quote  Post ReplyReply Direct Link To This Post Topic: Look what WC came to live on my farm
    Posted: 28 Jan 2010 at 10:32am
Finally got an AC UnStyled 1937 WC to come live on my farm.  A Dream come true for me!  Really Classy looking & I think very 'stylish' made ...to be an 'UnStyled WC..ha!  Don't know of anyone in my farm family or locally that ever had a WC, so what can you guys tell me about and recommend?  How can I fix it up? What do you paint the Allis Chalmers letters on radiator?
This usually cranks about 3rd/4th turn, but what causes the antifreeze to foam up and out ?  What size muffler / pipe & length supposed to use?
thanx for help & suggestions!
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 11:42am
Is that origonal?!? If it is, I would leave it like that. It looks to be in very good condition for it's age!
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 11:46am
Nice find, Bruce!  Where did you find it... NC?
gary ny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gary ny Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 12:14pm
Bruce nice find  I bought one out of a hedge row this past fall that is set up pretty toght but the tin is incredable.I have a 35 that my son is working on right now that was running and it also started about 3  crank but we found a crack in the water jacket that we are in the prossese of fixing,nice old tractor .I would flush the system out and see how it circulates that may stop the foaming or you will find where its pulling in a little air.It should be painted po 1 and you can get the right decals for it from Lyle Wacker.
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 12:45pm
And for the correct police make sure you don't put a WC decal on the radiator.  They never had one, the only place it should say WC is where it is stamped in on the rearend housing in front of the serial number.
MikeB (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeB (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 2:51pm
 Nice find Bruce. The 37 WC is the all time #3 Allis tractor produceded in a given model year. 29,208 units made that year making it by far the most common WC ever. Whats not common is how original and nice yours appears to be. It even has the period correct
checked rear tire tread. Has it been repainted before? If it hasn't it actually has more value left as is, but it is a 37 so you could choose to repaint and decal. My question is
did they even bother to put a Allis Chalmers decal of the frames of the 1937 models? I bet their were a lot of help wanted signs around the West Allis plant that year. Most modern plants figure about 250 production days a year. That would of been about 117 WC's built a day. These days a good day is probably 17 units.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 2:58pm
Flush the radiator. When I overhauled my WD I used dish soap as a lube for installing the sleeves with o-rings. I was confused after I ran it and it foamed up some. Then I remembered the dish soap. Glad I didn't put antifreeze in it first. Now i use vegetable oil.
Wink
I am a Russian Bot
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 5:41pm
That's one of the nicest unstyled WC's I've seen, especially if it's wearing its original paint. Nice find!
WC, CA, D14, WD45
Don Smith View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Smith Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 6:02pm
My 35 wc never had a muffler, just a pipe with the end sort of flatened . Please leave it in its work cloths. It is original once.Don
Brian(Va) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian(Va) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 8:48pm
Great find. When I got my 37 WC, it was the only one I had seen anywhere around central VA. Not many in this area.  It had steel wheels all around but it didn't take long to find a set of rubber to put on it, I liked the look but it was to hard to load and take to shows.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NC Bruce Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 8:52pm
Thanx fellows for the kind WC comments and good suggestions.
I'll try to post a 'cleaner' photo, but having trouble with my Insert Image.
I don't think its original paint, I'm pretty sure its been painted already.
I found it in KY, Murph.  It was on Craigslist.
I noticed the tire pattern was "old-timey", what do they call the tread type?
Were ya'll  saying AC may have left off the decals, due to fast production rates? I saw an old photo of the WC Diamond decal, but only for
I'll try to flush radiator, but with it foaming, does that mean air leaks, is thermostat working, radiator is full, but foams & runs out top after just a few minutes.
Did these WC s ever come with a muffler or just always a small straight pipe?
Again, Thanx for all your help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 9:01pm
There was an oval muffler for them, but they get so hot they damage the paint on the hood near them.  A short striaght pipe is best, but wear hearing protection.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 9:13pm
As I recall, It was called "Turkey Track" They are VERY good for pulling, and field work.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote NC Bruce Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 9:35pm
I just tried a new Image / photo ReSizer called VSO.  Let's see how it looks.
The WC photos were taken late at sunset, and may look orange....ha!
Post Options Post Options   Thanks (0) Thanks(0)   Quote NC Bruce Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 9:49pm
These photos are too large now.....!
Looks like orange paint on steering wheel too!
Hudsonator View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hudsonator Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 9:51pm
Dang, thats a nice WC!
What part of Ky did it come from?
There isn't much a WC can't do.
WD's just do it better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NC Bruce Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 10:12pm
It came last, from near Middlesboro, Ky., but the fellow said he thought it came from up North somewhere(Ohio)?  Supposedly the last man that owned it, kept it on his carport except for holidays to put in yard with lights on it?  Hopefully I can put on a set of front spoke wheels.
I've really never learned to handcrank an AC till this week.  Was told, go to bottom, catch hold, pull up 1/4 spin (never full spin).  This WC usually cranks 3rd,4th time, if you'll pull it hard.  I saw an old photo on internet, shows a WC in field in '37, with the crankhandle in "up" position.  I checked this one, and it's worn but there's a notch originally made to keep handle up....I guess to not drag trash or hang something.
The Throttle lever won't hold, very very worn teeth and lever.  Would you re-grind, or replace?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hudsonator Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 11:16pm
It never hurts to re-dress them with a grinder or a file, but the spring hardly ever is stout enough to keep the throttle in place.
My fix was to drive the lever-pin that the spring slips over out and replace it with a bolt and nut.  Hunt down a good used valve spring and place the spring w/retainer on top of the lever instead of the stock position of being beneath.  The larger diameter valve spring from the top helps support the lever better. Run the bolt down through the valve spring and hole that the pin once occupied, then adjust the tension with the nut till the lever stays put.  Its not original, but works.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2010 at 5:33am
One thing I found that works on my C throttle was to loosen the set screw and preload the throttle rod and tighten screw so that the rod and lever has a twisting force against the plate with teeth. Did I make any sense? Can't remember the set up exactly for a WC so it may or may not work.
Wink
I am a Russian Bot
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2010 at 6:24am
The foaming could be caused by a leaking head gasket.
Dusty
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2010 at 6:41am
You do have the correct wheels for a 37.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gary ny Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2010 at 7:01am
Bruce you will have alot of fun with that tractor it looks like it is in great shape.The fenders look real nice and not bent.Those are real hard to straighten when bent because they where made of real steel back then.And you are very fortunate to have the duel fuel system stiil intacked with the starter tank .Again Nice Find!! If you need anything feel free to email me I might be able to help
Max(ia) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Max(ia) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2010 at 8:20am
You even have some of the good stuff. radiator shield, little tank.  Crank is even bent like mine.  lol.    Like the dated rear tread.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2010 at 1:05pm
I would be thinking compression leaking into the coolant would be the cause. A block tester would tell for sure. If you pull the head, remember that most of the blocks you will find are cracked betwen the cylinders on the head deck and as long as they aren't spread open, just put it together with a new gasket.
