Removing AC G Spring trip Cultivator Springs
ktm911 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ktm911 Quote  Post ReplyReply Direct Link To This Post Topic: Removing AC G Spring trip Cultivator Springs
    Posted: 29 Jun 2013 at 3:03pm
Got a cultivator set a while back that has the 1 inch round shank spring trips and 2 disks.
The springs are in good shape, but not the spring rods which hold them, they are bent. I need a spring compressor that can collapse them to warm up the Spring Rod's nut with the torch and take it off.
If anyone has made their own tools I am looking for suggestions or a tool from a store, since my small city has nothing that will work.
Thanks in advance
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2013 at 5:07pm
Suggest you repost this in the Farm Equipment section as you are needing to repair farm equipment.  Also, participation there is much greater.  Herb(GA)
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2013 at 6:30pm
Try Harbor freight, on line.  You don't have to buy, but you can look at hoe theirs are made.  Search spring compressor or mcpherson strut compressor.
This page was generated in 0.719 seconds.
