wheelie pad height
firephight View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firephight Quote  Post ReplyReply Direct Link To This Post Topic: wheelie pad height
    Posted: 28 Jun 2013 at 9:58am
What height should I set them at can't be no higher than 10 inch from the ground
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2013 at 10:04am
When I built my wheelie bars I lifted the front as high as the rules for the lowest front end height for the places I was pulling and cut the bars and welded the pads setting in place on the shop floor.
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2013 at 9:17pm
Its easy to make then adjustable and set them for what you need depending on what your conditions are
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2013 at 2:13pm
It is also as imporant to have the pads at least 32 inches (MINIMUM) rearward from the center of the rear wheels to do any good !!!!!!!!!!!!  If you place your pads at 10 inches in height and only 24 inches rearward, you will easily upset the tractor. Farther back the better, up to a point of not being able to hook the sled chain.
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2013 at 9:39am
  Whatever you decide on just make sure they work.... Ours were built to 28" rubber specs and now we are  running 34" and they don't do what I like. We will re fab. this week.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
