Can a WD-45 pull a rock picker
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Topic: Can a WD-45 pull a rock picker
    Posted: 27 Jan 2010 at 4:35pm
Does any one think that a WD-45 can pull a rotary type rock picker.  It is a anderson that pulls directly behind the tractor with about a 6ft swath. It needs power from the PTO and Hydraulics. Would a WD-45 with loaded tires and snap-on duals have a problem with this in sandy soil or on hills.
Thanks in advance,
Denis
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 5:07pm
Denis if you do pull it with a WD45 please post a pic or two of it.
Don
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 5:24pm
45 with snap-on duals? please get a pic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 5:40pm
I can have a pic of the duals in a couple days but not of it pulling the rock picker till spring
Edited by Denis in MI - 27 Jan 2010 at 5:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 6:00pm
I guess they are actually clamp on duals that have 4 hooks that go in the power adjust rails and are threaded on the straight end and a nut is used to hold them on
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 6:12pm
We bought a brand new vermeer rock picker a few years ago. We were told you could run it up to 4 inches in the ground. Man was that thing a mistake. Turns out you can run them in the ground but it will work more like a paddle scraper. You get a bucket full of dirt with whatever rocks were mixed in with it. We pulled it with a Jd 6420 which is about 95 horse. Pulling it a couple inches in the ground you couldnt really tell it was back there. If you ran it ontop of the ground like i think their really meant to you shouldn't have to much power trouble depending on how fast you wanted to go. Traction would be your main concern I would say. Ours had pretty big dump cylinders so I dont know how you would be on hydraulics. Hope this helps, if i am wrong on how these are supposed to work though please correct me. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 6:25pm
This is the same model of machine, owners manual say it is supposed to dig in to the ground but it will not work right in real heavy or damp soil works best in sand.
Edited by Denis in MI - 27 Jan 2010 at 6:26pm
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 6:55pm
Can you go to the manufacturer's website and see how much HP is required for that model? That might help you some.
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 10:53pm
I seen this pic on yesterday's tractors.  It is a Cockshutt 40 pulling a Degleman rock picker.  A Cockshutt 40 is roughly same hp as a WD45 but the larger tires would surley be a help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 11:10pm
This one belongs to bigfish Larry.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 11:11am
That looks neat! I knew there where duals for the 45's but never seen 'em. How rare are they?
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 11:48am
Duals must really help that pedal tractor too...!LOL
Greg Kroeker
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 11:55am
Looks like it'd need 'em pulling that big WD45 around!
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 4:52pm
Don't know how hard they would be to find now but I bet there were lot of them in the '50s and '60s.  I know my Grandpa had them on his 45.
Lot's of today tractors have 28" wheels on the front, maybe something could be made from front wheel assist duals.
