WD Hydraulics
KC/WD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC/WD Quote  Post ReplyReply Direct Link To This Post Topic: WD Hydraulics
    Posted: 27 Jan 2010 at 3:31pm
I think I'll treat my WD to fresh hydraulic fluid, she deserves it!
What is her capacity, 5 glns?
Thanks,
KC
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 3:56pm
Hydraulic pump says 5 Quarts.
Greg Kroeker
roughstock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roughstock Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 6:24pm
I hope your fluid change goes better than mine did. I ended up using two gallons after a line to my loader blew.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 10:31pm
It ain't much but 5qt seems like too little.Been a while. Just be sure to check it as full with lift arms up and engine off.Wipe the dipstick off and re-insert for accurate reading.You can check it before startup but oil will read higher on the stick before you wipe it off which can make you think it's got enough when you don't.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 10:33pm
Also pull the little pipe plug at the bottom of the control hsg to drain it all.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 10:36am
My WD-45 Owners Manual says 6 Qts.
I also advise doing what Steve M. says; there may be a bit of sludge in there.
