28 volt alternator
doctorcorey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Topic: 28 volt alternator
    Posted: 25 Jun 2013 at 9:52am
 Anyone on here converted a hd7g or hd6g for alternator? If so, what alternator did you use?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2013 at 11:45am
You can find some of the older GM alternators used on heavy trucks that are the higher voltage . Unsure if you can convert something like the 10SI to higher voltage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2013 at 12:12pm
Corey, there are 24V alternators on the ebay site a lot, can do a google search for 24V alternator and will come up with a load of them. Ours are not 28V but 24V and positive ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2013 at 12:18pm
Depending on what the system was spec'd out for @ maximum amperage, some Delco 21 & 22 SI's fill the bill quite nicely on a lot of applications. If bigger amps/power are needed, a Bosch "AL" series Alternator would probably work quite well. All of the Alternators I mentioned adapt quite easily to industrial and AG applications. We have these large Alts in stock...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2013 at 12:49pm
Charging system specs for the old 7G's was 15 amps, more would be better but as they don't often run lighting the lower rates work OK.
Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2013 at 2:32pm
Thanks, boys. Yes it is for a 24 volt system. I'll be running floodlights on this machine but a truck alternator would probably work. I usually just charge both batteries before I start working the machine, as they provide 10-15 starts without replenishment, but I'm getting tired of doing that and battery life suffers if you don't keep them hot, as well as slow cranking. I'm lucky; my tractor usually starts by the third or fourth turn. Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2013 at 11:11am
Have also seen individuals rig up a charging system for 2 - 12V batteries then have a solenoid that sends 24V to starter but runs everything else on 12V
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2013 at 1:15pm
I found a source for the 24 volt regulator (internal) for the 10si and 15si delco alternators. Now I can't remember my machine is positive or negative ground?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2013 at 2:42pm
Make it whatever you want - just reverse the ground cable - then the wires on the amp gauge.
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2013 at 5:01pm
If I recall correctly Orangeman had a posting on alternators a while back.
I put a Bosch 24volt 50 amp one on our AC 45 grader.  Was able to weld the Bosch 2-ear mount on a generator mount from a HD 11 (a straight surface rather than the more complex moulded one from the grader) and used the grader adjustment strap.   The pulley from a Delco (ex HD 11) generator had the right bore for the alternator.  That shaft doesn't use a key and I had to use a bit of Locktite to keep the nut on.
Had to change the system to negative ground, which seems to work ok.
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2013 at 8:43am
Change to negative ground, and the starter still turns the right way?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2013 at 4:07pm
Seems to work fine and spin the same way
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2013 at 12:09am
my 6ep had been changed to - earth. when I rebuilt generator and fitted new to me regulator just polarised it and every thing worked ok
tits tyres and tracks
they all cost you money
Lee Bradley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lee Bradley Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2013 at 1:14pm
Because the field magnets are electro-magnetic opposed to permanent magnets the magnetic field is reversed when you change polarity and the starter turns the same direction. Some of the smaller starters use permanent magnets (garden tractors, lawnmowers, etc) and would reverse direction with a polarity switch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2013 at 11:12am
I finally remembered the polarity/rotation thing for field-coil type motors. Thanks for all the advice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2013 at 8:59am
Hey Corey, I have a fella in O'Fallon MO that will rework my old Delco Generator, he is parts and labor but a better deal I haven't found. We only need to charge batteries after a start so the 10/15 amps these made would be enough.
Was told by Sydenstricker Tractor there is supposed to another rebuilder around Cuba, I did find Harold' Starter and alternator Svc, 573-885-7838, listings say there are others, may ask a local auto parts house if one nearby.
This page was generated in 1.051 seconds.
