4WD WD
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Topic: 4WD WD
    Posted: 26 Jan 2010 at 10:15pm
roughstock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roughstock Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 7:12am
I am at a lost for words..... that's...... different.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 10:00am
Hard to call that a WD anymore!  Not much WD left!!
Matt (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 3:23pm
looks like it was a pretty sweet machine in its day!
1955 WD-45 with factory PS
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 3:29pm
I agree with Albert Phil, not much WD except for the frame rails up and from gas tank forward. Although....it looks sweet. If all the mods were engineered and installed correctly, and it actually works, it would be a unique machine. Paint it up and add some logos. Sure would turn some heads.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 6:23pm
kind of the same idea as the H-1 experimental based on the "C", in C.H. Wendel's book:
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 7:01pm
Bill, I was just day-dreaming the other evening about how I could do something like that with some of the junk I have lying around. I was trying to figure out how to use a FWD axle from a Kubota or something like that. Just couldn't figure out how to get the power transmitted from the tranny output to the front axle. I think that would be pretty cool, even though I would be butchering a potentially good tractor.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 7:05pm
someone made a pretty clean one from WC's that was in the OAN several years ago,
or you could just step up to the ones Thompson made out of UC pieces
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 7:20pm
That 4WDWD45 needs to be restored. Maybe add a pickup cab to the back end and use it for gettin firewood outa the timber.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 11:43pm
would have been neat if the H-1 had gone into production though, it would be a challenge to build given that clark custom built the tranny, far from a bolt-together project....on a WD though one could run a shaft forward from the PTO gearbox instead of backward to supply the front axle, you could then use the PTO lever to "engage" the front-wheel assist like on a modern tractor, except they had a live pto and it ran nearly constant speed so it wouldn't drive with the back axle
Edited by Bill_MN - 27 Jan 2010 at 11:46pm
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 8:31am
I need some help here.
There was a tractor like this at the Coming Home GOTO show at Union Grove WI. The owner had it hooked to a trailed and drove it with rains from the trailer, he was giving rides. Here's where I need some help. I think, according a sign on the unit, some other company produced a few of them.
Dusty
gary ny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gary ny Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 9:21am
Dusty those I think were call the horse made buy another company using the b motor,I have been trying to find some info on them after seeing them on the rfd classic tractor show .Very neat little machine.they were built for people that wanted to still use there horse drawn equipment.I haven t had much luck finding anything on them.I though I had heard that they were built somewhere in Ohio but im not sure .
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 9:26am
It was called the Harris Power Horse.  It was one of a few 'rein drive' tractors out there.  They were supposed to be an easy transition from horses to tractors.
They were a lot like a an older skid steer [Bobcat] characteristically.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 5:02pm
