7000 series dash lights
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Topic: 7000 series dash lights
    Posted: 26 Jan 2010 at 7:27pm
 Does anyone know when they changed the dash lights on the 7000 series from the round individual lights to the rectangular cluster? Just curious because I have tractors with both.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 9:22pm
Probably in 77 or 78 when the paint scheme and cab style changed
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 9:38pm
I thought it was with the change from maroon to black belly, but apparently some of the late maroon bellies had the rectangular lights.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Andrew(southernIL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 9:39pm
Our '77 model maroon belly 7000 has the cluster
Edited by Andrew(southernIL) - 26 Jan 2010 at 9:40pm
If fishing is a sport your looking at an athlete
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 9:45pm
I think around 76. we had a 75 7000 with individual lights, and a 76 7040 with the cluster. both obviously maroon chassis tractors. hth, Ed.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 10:01pm
My 7050 and one 7060 had the individuals, and my other 7060 has the cluster and i beleive its a 76. I was just didnt know if someone put a black belly dash in or if they changed it before they switched to black. It was a wiring mess back there when i split it. thanks
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 10:32pm
I thought i might also add that my 7050 has a fiberglass roof maybe plastic, when my 7060 has a metal one. The 7050 is a '74' and the 7060 is a '76'. Would this be a aftermarket? I wish it had a metal roof that other thing is breaking around the edges.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 5:47am
1976 is the year Allis patented the hour meter technology that would record a truer reading. That could be the year they installed the new technology along with the cluster gauge. My old 7050 records wether or not the tractor is running. I think I've added about 500 hours to mine by me or my Dad forgetting to turn the key off. I bet the previous owner did the same. I sure like that tractor.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 12:40pm
The cab roofs were changed at some point, maybe at same time they moved the flasher lights from the cab top to just below the cab top?
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2010 at 9:37pm
The plastic cab roofs can be changed to a metal one with no problems other than moving the warning flashers to the cab. I did a 7050.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2010 at 10:29pm
I guess I never noticed that the flashers were in different places. I just figured that the plastic top would be a newer thing, didn't figure they would go from plastic to metal. thanks
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 9:43pm
Does anyone know where you could buy a new cab roof, either metal or plastic? thanks
This page was generated in 0.043 seconds.
