230/262 gas and diesel crankshafts
Jamie NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie NC Quote  Post ReplyReply Direct Link To This Post Topic: 230/262 gas and diesel crankshafts
    Posted: 26 Jan 2010 at 4:12pm
I would like to know if the gas crankshaft is a drop it swap for the 230 buda diesel block.
Need to know what will work before I start looking for a replacment crank for a 45diesel.
If anyone has the casting numbers also.
Jamie NC
Allis tractor puller CA WC WD D17
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 5:12pm
Seems like you need to swap the cam from a 262 in with the 262 crank. If I remember reading correctly, there are notches in the cam to clear the connecting rod caps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 10:59pm
I believe the 230 gas and diesel crankshafts carry the same part number.
At one time Illini Construction Equipment had a few NOS 230 crankshafts on the shelf.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 5:56am
Yes the crank for 230 is the same for gas or diesel. The cranks for 262 are the same, except it is a longer stroke. MACK
