Projects
Steve allis dozer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Topic: Projects
    Posted: 18 Jun 2013 at 7:10am
its pretty quiet on here lately does anyone have an pictures of projects they are working on?
regards steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2013 at 12:18pm
I am working on getting my project to the farm, then the photos, if I don't regret it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2013 at 3:11pm
Have to add, anyone know the weight on a full dress Turbo 344? I will be dragging a headless block from one to pull and add the full dress unit from mine, less than ton? with the converter still attached but fluids drained?
I will be using the 180 for removal of the first to see if it will even do the job, if not will probably fabricate my own floor solid gantry to pull it and slide it to one side. Wish I had a backhoe at this time.
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2013 at 6:29pm
My AC 6000/7000 manual says you must have 2000# lifting capacity or 3000# capacity when pulling engine with transmission. I used the loader on my International 3444 TBL. It was bearly up to the task of pulling the block and flywheel without the cylinder head. I puled it from the side with the HD6G shovel down. I broke the water bypass tube during the lift. Pulling the motor from the side I had to lift the motor quite high to clear the shovel. Next time I will pull from the front with the shovel up. Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2013 at 6:43pm
If you pull from the front you have to lift the assembly 12" If you use a gantry, the beam has to be the length of the crawler plus the lingth of the engine and torque converter. I had a great dificulty with the rear engine mount alignment. That is why next time I will pull from the front.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2013 at 4:55am
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2013 at 4:56am
bending some new brake pipes for the m65 grader I am working on
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2013 at 7:26am
looking quite professional
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2013 at 3:00pm
Good workmanship!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2013 at 4:56pm
still awaiting my donor unit, Zimmerman's driver has been tied up and I am pretty low on the list. Will post photos as it does get home.
