Off color question ;JD 4020 axle
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: Off color question ;JD 4020 axle
    Posted: 26 Jan 2010 at 6:23am
What is the rear axle diameter on a JD 4020 ?
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 12:20pm
Shop manual, parts catalog, owner's manual don't say. I have measured my '68 at 4-3/8" and made a note in my owner's manual.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 6:28pm
Maybe 3 3/8"....not 4 3/8".
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 6:37pm
Dr Allis is right, A 4020 axle is 3 3/8".
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 9:36am
Well, I checked again. My notes in my owners manual sure is 4-3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 9:37am
Well, I checked again. My note in my owners manual sure is 4.375, but the SM says in print 3.375. So it must be 3.375.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 3:54pm
Gerald J.
Well Gerald, I was told by a friend (Mike) not to be so hard on you, So in a nice way my tape read 3 3/8" on my 4020 axle. LOL
But the tape can be wrong. LOL
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 8:01pm
I looked today. My 4020 axle is THREE and three eighths. Must have remembered wrong the day I came home and wrote it in my owners manual. I suppose I should correct that entry.
Now all I need to do is get it running, I turned on the ignition switch and the electric fuel pump did not rattle. Its been about a year and half since it last was run. Guess I have to charge the battery if it has not frozen and split these below zero months. Then change the sprayer tires back to regular tires.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 8:59pm
Hi Gerald,
Please be careful with the frozen batteries, Let them warm up first then charge them up. A frozen battery can explode.
