Stuck oil pressure relief valve on G
Farrell(Utah) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Topic: Stuck oil pressure relief valve on G
    Posted: 25 Jan 2010 at 9:26pm
The pressure relief valve on my G is stuck.  We have tried soaking it with PB Blaster, heating the block, and tapping the block gently with a hammer.  Nothing seems to get it to come loose.  What are some of the tricks that some of you have tried to solve this problem?  Thanks as always.
A(1937), 2 G, 2 WD45 diesels, 6 WD45 gas, UC, 2 WD, D17 gas, WF, Farmall 400, D12, Kubota B3030
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 9:29pm
Run a tap in it or a easy out .I
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 9:37pm
I should also say that we have tried air pressure through the oil galleys in the block.
