ones i should look out for
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Topic: ones i should look out for
    Posted: 13 Jun 2013 at 2:34pm
hey guys going pulling for the first time next weekend and will run the farm stock class, 10 percent over rpm 2.5 mph limit no cut tires things like that, any particular tractor i should look out for, ones that will give a wd a run for its money or flat out embaress it? here is the list of pullers from last year and there will more than likely be no more (well i guess one and thats me) and no less tractors there, meaning we expect everyone to show up that did last year http://www.ottercreekpullers.com/Ashton_Tractor_Pull.html, any of them that catch your eye? if there are so few people running the open class again we may run open just for a guarnteed trophyLOL
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2013 at 3:41pm
The Coop E3 can be a tough tractor. The Farmall H also if the motor has been built up.
But it looks like your main competition will be other AC tractors.
Charlie
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2013 at 3:43pm
What class are you pulling?
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2013 at 4:56pm
3500, 4000, 4500 and depending on if we spin out or power out on 4500 maybe 5000. basically we will just keep going up in weight classes until we run out of power. it has been rainy here alot so there may not be much traction, allowing us to run higher weight class
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2013 at 5:04pm
i may not have to worry about the farmalls very much, according to tractor data the farmal has a 2.6 mph first gear, meaning they go too fast so they have to throttle down a bit. the guys are very strict about speed, especially since not many are a fan of farmallLOL
The Other Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Other Orange Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2013 at 8:25am
The more you throttle back the better. As the tractor lugs down and slips the tires you can add more throttle and keep your speed up. I run a 4.2mph gear in the 3mph class and had the best results vs the 3.5mph gear. Yeah the horn gets me once or twice a year but its worth it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2013 at 4:44pm
so throttling back is better? if you could explain that some more i would appreciate it, it just seems a little counter productive to me ( never done it before though, 1st time june22) i figured it was wide open and roar down the track
EricSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2013 at 6:22pm
If you run a higher speed gear you just can't give it full throttle till your down the track were your will slippage will prevent you from speeding hopefully. But you need a little extra HP to run that faster gear and to be able to idle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2013 at 6:31pm
this is farm stock andar open class so farm stock will be first gear only and open maybe second depending on track condition
WCinVA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WCinVA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2013 at 6:39pm
Dot worry about anyone else. Just do your best!
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2013 at 6:39pm
Okay but this would give the farm all a slight advantage given the drivers ability and if he or she has enough engine with there faster gear
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2013 at 6:40pm
Dry I meant to say faster first gear
WCCLASON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WCCLASON Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2013 at 9:16pm
Not sure if hes got it yet...This is how i pull as well. I run first gear in a 240ci motor and i run stock farm and we have a 3.5mph limit with a digital speed board. i also run 13.6x36 tires on one WC and 15.5x38 on the other. Now i am only about half or a little better throttle comming down the track and i watch my speed and keep bumping the throttle a little more to keep it as close to 3.5 as i can, more momentum and speed will get you farther and one you start slipping your right on the throttle were you need to be.
So ....it works good for use but its not always the same for everyone else. Hope it all works out for you....Sorry if you did understand and i am just saying again for no reason.
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2013 at 7:29pm
good news, the coop e3 wont be running my class anymore as it has had a 305 v8 swap so it cant run in the same class as me. it is also for sale on craigslist so if anyone wants to but a v8 coop e3 ask and I will get the link for it
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2013 at 10:04pm
post it couirious what it looks like.
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2013 at 10:27pm
little rough and cobbled together http://siouxcity.craigslist.org/grd/3875645239.html
Mickel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mickel Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2013 at 3:35am
__________________
There're a lot of information about Swtor Gold,Aion Gold and Rift Platinum,hope you can get something what you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2013 at 11:11am
reported
cornbinder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cornbinder Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2013 at 9:24pm
305!! LOL those things are boat anchors. I wonder why someone would go threw that amount of work and put a useless engine in it. he must not wanna win.
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2013 at 10:36pm
reported
was it something i did or?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2013 at 7:32am
NO!! It's the spam post right after your post and right before my "reported".
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2013 at 7:53am
ohh, must have been deleted before i saw it
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2013 at 5:04pm
Nope, it's still there. The post by "Mickel" is Spam
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2013 at 8:13pm
ahh i see now
