HD5 pins bushings etc carco winch
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Topic: HD5 pins bushings etc carco winch
    Posted: 11 Jun 2013 at 12:44pm
 I have a little 7+ton HD5 dozer with winch
 Tracks are not the greatest... Heres a pic.
 Must be the new style see thru bushings? LOL
 Think a simple pin and bushing turning would do it?  LOL
Does anyone have:
 1. dimensions for the links?
 2. New pins and bushings .. if links are acceptable yet.
 3. or some good rails?  and possibly sprockets too?
 Here is pic of worse side.
Think this sprocket is cherry?
 cut off/weld on or find nos ine piece sprockets?
 Also Does anyone have a bit of info on a Carco winch E-24?
  One lever has forward nuetral and reverse , does the other handle have a brake? My handle is not attached at the moment.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2013 at 2:47pm
The HD5 new links tightness are 3.687" and what I can see you need pine,boushing and sprocket and for the whinch you should have a lever for the brake and second for reverse and forward
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2013 at 3:03pm
Gemdozer, I think I need 66 pins and bushings, 33 of them for sure.
  Are whole or weld on sprockets available yet?
  Maybe have to set up on a jig and weld up and grind down the teeth and then heat treat?
  Tried  http://www.crawlerheaven.com/tracklinks_chart.htm but this link doesn't work for me.Disapprove
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2013 at 4:15pm
There are parts on eBay located in Maryland. Weld on sprocket rings are available. There are 2 different sprocket splines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2013 at 4:37pm
ac_sd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_sd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2013 at 4:47pm
I've got 2 sets of good tracks and sprocket rims for HD-5B... Located in San Diego (long way from Wisconsin).....
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2013 at 5:19pm
the winch levers: one is for forward/reverse, the other lever is for engage/freewheel. there is not brake on these winches. cables usually freeze up and do not work properly. I have a used set of tracks, the pins and bushings need to be turned, inside wear more than outside wear. rails are decent, slightly rounded on the outside edges but still useable. I think berco still has the weld on sprockets but not sure. pm me if interested. located in pa, a good ride from Wisconsin.
This page was generated in 1.086 seconds.
