tube style tip bars
firephight View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firephight Quote  Post ReplyReply Direct Link To This Post Topic: tube style tip bars
    Posted: 09 Jun 2013 at 11:16pm
Any one have some pics for a wd / wd45 of tube style tip/ wheelie bars
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2013 at 7:34am
  I am sure you have saw mine on the facebook page??? goes back in the winter post.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
Post Options Post Options   Thanks (0) Thanks(0)   Quote firephight Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2013 at 8:54am
Sorry round tubing like the big tractors have. not square. I made some bit need to know where about to put the center bars for stength in
Post Options Post Options   Thanks (0) Thanks(0)   Quote firephight Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2013 at 8:56pm
this is what I came up with
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2013 at 7:42am
wow! looks great!
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2013 at 12:30pm
I made a set similar this winter when I was makeing a new drawbar and hitch adjustment assembly, but I ran the center tube different for added strength.  But you are not going to have an issue the way you have them on. I made them from 1.5"od .083" will thickness chrome moly tubeing to save as much weight as I could.
I wanted to run them at an angle, with lesser bend than a 90* in them but the way I had to attach to the chassis and keep some clearance in places wouldn't let me do it without more modifiations.
Sorry pic is crappy, but you should be able to see what I mean.
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2013 at 12:37pm
I need to build a set for the WD-45 sometime when time allows, I'll do something similar to yours there firephight.  I'll just use .083" wall 1 1/2" electric welded tubeing for it, it's less than $1 per foot at the steel yard and I'll never hit them hard enough to bend with an old Allis.  BUt for now our "farm stock" or 4mph rules don't require them anywhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote firephight Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2013 at 8:53pm
If I could make them over I would figure out a diffrent way to attach them to the tractor. The rules stat that the tractor should be able to be jacked up in the air off of one of them in the heavest weight class
This page was generated in 0.089 seconds.
