What is in your shed waiting to be worked on?
AndrewGubbels View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndrewGubbels Quote  Post ReplyReply Direct Link To This Post Topic: What is in your shed waiting to be worked on?
    Posted: 24 Jan 2010 at 8:37pm
Hey guys, I was sitting here thinking in the middle of a blizzard what I need to be working on before to long.  I have a wd45 diesel high crop that I would love to get to restoring this summer and just making it just how I want it.  My Dad, Brothers and I just love going on tractor drives with any allis chalmers tractor and I think this would be a great one!  I am planning on making an extra seat so my wife can ride along with me and just adding some additional things.  I think I may add a radio and some extra flashers or lights.  Maybe some front fenders.  I just wanted to share.  Do any of you guys have any projects that are just waiting for you in the shed?   I have more than one but this one I am really excited about.  Thanks!
Andrew Gubbels
Andrew Gubbels
Gubbels Restoration
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 8:42pm
Well lets see, I have a 58 D17D that I have the head off and need to pull the engine to fix it properly, a 52 8N Ford that doesn't run quite right and has a couple small leaks after I installed a new long block in. A 383 Chevy engine to drop in my 98 Silverado. I'll probably put a soft parts kit in the trans while I have it apart. Sheesh, I got too much to do...
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 8:44pm
Finish the tranny on the D-15 thats in the shop before I have to go back to work. I'll be in Daytona Feburary 3rd. I'll still need to paint the hood, fenders and radiator shell. I'll most likely paint it when it warms up some. I'll have the loader back from sand blasting when I finally get home mid-march. I hope to paint the loader at the same time. I also have some finishing touches on my 9020 that I went through. I have an HB212 to convert the hydro to a late model Sundstrand hydro and ad power steering to. Replace the right side fender and door of my pu truck. Still have a few service things to do to my rig and trailer before I leave for Daytona too. Think I have enough to fill my week and a half up?
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 8:45pm
Right now this is the only post I can open on Farm Equipment so I might as well add my 2 cents.  In the shop is the 1949 C with a bad cylinder and piston, an IHC super A that needs to be finished and painted and a 1959 Jeep FC 170 with a 327 Chevy that needs a paint job and glass and a lot of odds and ends.  Then outside is the.... ok, enough for now!
Allis Express participant
Brad MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad MI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 9:04pm
#B450 with arched adjustable front axle, shallow dished rear centers on the 5 lug/spline adapters pulling an early B steel framed breakaway plow.
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 9:15pm
D-17D that blew a head gasket and the old owner left the coolant in the cylinder and it rusted causing the engine to sieze up, 1938 B in need of a full engine overhaul that I have been slowly gathering parts for, a IB that needs fenders, brakes and paint, my sisters B that needs two front wheels, one rear swapped to the new tire, and paint by july for local tractor show, WD-45 that just needs finished cleaning and painted, and for non AC I have a 47 John Deere A that the old owner forgot to install the oil pump drive after a complete overhaul, 3 ford N's that a lady gave me after her husband passed that I hope to fix and sell, and a fordson that a guy put oil down the cylinders to keep it from locking up which effectivly lossened all the carbon and rust which is now floating loose in the cylinders and he took the carb apart and lost most of the pieces. Of course their is alot more to work on around here but that is the general stuff that comes to mind
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
jeffnil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffnil Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 9:29pm
220 farm stock, changing exhaust manifold and new plumbing for air intake, and 220 pro farm, in many pieces waiting to be put together.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 9:32pm
Ah, let's see: there's the C whose crushed gas tank and gummed up carb need attention; the G that needs its brakes ungummed and engine work (it blows smoke out the breather tube under load); the CA whose hand clutch doesn't work and whose brakes are the pits; the D14 that needs a snowplow setup for next winter.....and the WC that needs a GOOD paint job! Now, if I can just get the workshop finished, we'll get started!
WC, CA, D14, WD45
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 10:03pm
1919 -E18-30
1940 - A
Jim-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim-Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 10:06pm
51 CA : Needs rear axle seal replaced. Also want to get something on it to move snow.
31 Model A sedan : Finish restoring.
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 10:15pm
I have an old auger wagon I need to get finished for me and I have an Oliver crawler (I really don't know the numbers on it but it is small an old) that gets restored for a customer. I need to pickup a free CA.JP
Brad-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad-MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 10:31pm
In the process of a complete teardown, fixing issues and rebuild to the motor from my '38 A.  Got a different block coming, along with a set of main bearings, from my "uncle" Fred in Pa.  The heads are at the machine shop, along with the crank to get polished.  Gotta get after some liner o-rings.  Gaskets are on their way.  Gotta get my headlights and generator mounted up after the motor's put back together.  I was thinking about getting a few things chromed out...kinda like "pimpin' my A out"  lol  I probably won't do any new sheet metal or paint or tires until next winter.  I want to get it running good, get everything mechanical checked out and re-done if need be, and just use it a little before it gets the full make over treatment.  Also always on the lookout for the next project...lol
1930 U
1938 A
1941 WF
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 10:32pm
IB restore for my granddaughter, D17diesel engine and power director rebuild, D14 transmission bearing, brake job, lift cylinder rebuild, transport valve to install after I make a return line, and possibly some engine work.  A 190XT fuel system clean and repair, and pump and injector rebuild.  1945 WC wide front rebuild and install, install Sherman overdrive.  By then my money will be long gone.  LOL
LarryWC In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 10:37pm
Actually,,,I have a WD45 waiting on a shed,,,,so it CAN be worked on,,,,,,:)
www.allischalmersmuseum.com
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 11:02pm
Put engine back in 190xt series 3, and finish rebuild on wd45 diesel engine, tear apart d-17 diesel to find the bad valve and replace rear seal and rings, ib that needs fenders and a pintle hitch, and that is just to get started actually all of my stuff needs something ha
lukeWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lukeWI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 11:20pm
gotta finish putting the motor back together for my series II d-21
MilesGray (CO/KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 12:06am
About everything I have needs some work... 44C w/Woods L406 needs electrical work for the Starter/Alternator, 38B needs the rear tires unloaded, 38B w/Woods L59 needs the crack in the block repaired, 38B w/Sickle mower needs to be rebuilt. 89 Ford F150 needs Fuel Injector work... Unfortunately all this equipment is in Kansas and right now I have found I'm having a hard time getting out of Colorado!
LOL at JohnCO... I've seen your yard...
Miles
Edited by MilesGray (CO/KS) - 25 Jan 2010 at 12:10am
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 12:24am
Well if it wasn't for that RED trailer you parked in my asparagus field there would be plenty of space! LOL
WD in kansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD in kansas Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 12:58pm
 1967 Harley Davidson Electraglide that needs a complete restoration. Some sort of electrical problem on my little Duetz Allis garden tractor. Too cold in the barn to do anything right now!
1950 WD, Duetz Allis 613
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 1:01pm
1940 B and 1952 B. Both are just fine but I'll need to wake them up from their winters rest come another month or 2.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 1:23pm
Well...nothing real major,but a lot of knick-knack stuff on most everything! LOL! If I keep buying things though,I'll never get caught up!  Rick
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 1:38pm
Starting on this one, my first tractor. Cool feeling to be truning wrenches on a machine that my grandfather nurtured, and maintained! Uncoverd some really foul smelling crud this weekend.
Jeff
ust
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 1:43pm
Got a 54 Willys Jeep in the garage I need to get running.  A D14 sitting by the barn with a stuck engine.  An I need to finish up the D14 I started last year.  Hopefully I won't run into anymore surprises on that one!  Just fix things to run and play with, I don't restore.
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 1:45pm
NEED TO GET WORKIN ON MY D 15 ..CLUTCH AND ENGINE .. SOME DAY IT WILL GET WARM ...
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 2:14pm
finsh my case 730 lp high crop. me and dad also are rebuilding a ford 4000 .
start on a case Vah.
then i need to decide what allis high crop to restore i think WD high crop.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 3:35pm
Finish WD 45 replica made out of old wheel horse for the grandson. Find out what is grinding in my 71 Jeep J2000 pickup rear end. New starter drive on the WD45. New plow shares on the plow. Drag in a WD wide front carcass that I have had my eye on awhile. (possible puller; dont tell the wife)
Maurice/Pa. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maurice/Pa. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 5:52pm
     Over hauling the 45 diesel I got in Dec. the head will be done in a couple of weeks.
I have the block tare apart yet.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 6:00pm
john deere A ,allis ca , d14 my wd  puller new engine, a lerio tractair, farmall md.  its easier to create more projects than it is to complete one.
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 7:46pm
1960 D-17D that need completely overhauled and restored. dont know if we'll get to it this winter.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
Andrew(southernIL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 7:58pm
That's easy everything we own except the year old BW180 Woods and 10 year old 1020 grain platform. So basically everything that needed it last year and previous years too but as long as you know whats broke you can make it work for a long time. Just like a tractor as long as you know whats wrong you can drive it for a long time except these new ones that can have a sensor go bad and leave you stranded.
