cutting tires
farmer_rob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Topic: cutting tires
    Posted: 24 Jan 2010 at 7:47pm
i was wondering how someone would actually cut tires. would using a hand held thickness planer work. what is the most perfered method to doing this job
thanks
if farming was easy everybody would be doing it
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 3:16pm
bump
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 8:17pm
I have not actually cut tires, but someone told me once to hook up to something bigger then my tractor and then spin the tires in reverse on concrete so sharpen the edge of the treads, holding each brake to run each side.  I have to say it worked pretty good and left a fairly decent sized pile of rubber shavings on the ground.  Whether it helped or not is a matter of opinion, but I thought I did pretty good.   The other thing that I was told to do which I haven't done yet is either widen the rims I have or get another set of rims that are wider and use the same set of tires.  The idea I guess is that it takes the same tire which is normally round and flattens out the tread pattern which gives better traction.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 8:20pm
There is a wheel you can buy that fits a small angle grinder. I understand it is a messy job.
Jamie NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie NC Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 10:05pm
hand held electric wood planer,and strong arms!!
Allis tractor puller CA WC WD D17
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 6:23am
I have done all the above. Fastest is putting the tractor in reverse and use running water witha garden hose on the ground. I did some 24.5x32 rear tires with a Bosch planner and it worked Great !!!Took 9 hrs and shaved 51 lbs of rubber off in a 33 gallon garbage can. Used 2 gringing wheels for 1 big grinder to do the top cut and a small cup style grinder to do the front cut with a 4 inch grinder. Took about 7 hrs to do a set of 20.8x38 rears. Wow what a differance! The planner works the best. Use  carbide bits in the wood planner when doing it. I had a big house fan on my back blowing the smoke away and be preparred to get your shop very dirty. I had black ALL OVER THE SHOP. Ity is a tiring job but worth it in the end.
Take care and have fun, Darryl
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 7:00am
Yeesh, Darryl! Sounds like one of those nasty jobs ya wanna do only once!
WC, CA, D14, WD45
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 7:38am
if you can find someone that does it proffesionally ,it will be money well spent,they can get every bar uniform and will save you the health risk,time sore arms and willl have every bar on the ground when you pull
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 10:02am
I have a set of 11 x 28 tires that are already cut down and good wheels for a WD/WD45.  I would trade for a set of tires/wheels that are not cut down.  We can discuss $ to even up depending on condition of your tires/wheels. Michael 816 898 7277.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 11:49am
Ok, I have to ask, WHY would you cut down tires???? I'm as curious as my cat !
Jay
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 3:07pm
Rob, I would get the wheels from a company like Epperson Tire Cutting, or someone like that.  If you know of someone going to Louisville, they can buy them in the pits there.  There are coarse and finer wheels, depending upon how much you want to take off.  You can even get them custom cut, too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 6:39pm
ok thanks kevin
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 11:08pm
Jay
the question was asked maybe we could get the experts to give reasons why  this is done.
thanks
No barn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote No barn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2010 at 6:43am
By cutting the top of tire at a angle (lower in rear) and forward at top of lug from bottom on front side it puts all weight at very front edge of tire. Makes tire bit in like edge of shovel. Lowering the lug height Kepts lug from rolling backward, and you get some depth control.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 1:07pm
Thanks to No Barn for the info as to why anyone would cut tires! Seems like a lot of work ,is it for farming or for tractor pulling use???
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 1:58pm
you would only go to that effort for pulling
This page was generated in 0.110 seconds.
