Local 5000 lb pull
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: Local 5000 lb pull
    Posted: 02 Jun 2013 at 1:35pm
I put my camera on the sled, see if you can spot me!
[TUBE]http://youtu.be/ayuB00yu3Vo[/TUBE]
Charlie
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2013 at 3:58pm
good looking jd
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2013 at 6:35pm
Ha!
Actually yes there were several nice JD's there
Charlie
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2013 at 7:02pm
You were driving the only Green one right?!??!?
Nice job!!
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2013 at 5:35am
Full pull, in pull off the JD A got me by 10'
Charlie
cornbinder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cornbinder Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2013 at 7:13am
thanks for the nice footage! that A had some serious added power underhood, he effortlessly pulled in 2nd gear, didn't even pull the motor down. congrats on 2nd place though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2013 at 7:53am
I think he has 600+ ci. Your insides feel the pressure waves standing next to it.
I ran 1st Hi no problem, should have throttled back some and let it grab more.
Charlie
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2013 at 9:15am
I pulled twice at our local antique show...got first both times with the WC.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2013 at 9:51am
What classes do you run the WC in?
I usually run Stock "A" class which means you must run everything stock (that you can see), even weights.
I think I am switching to B class (3.5 mph) to be able to use suitcase weights.
With 1 front stack weight, 2 rear WD style, no fluid, I am at 4998 lbs. I have 2 more WD (Different style) weights that put me at 5330. They don't feel 165 lbs each but they are heavy. I think I will make a belly suitcase mount.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2013 at 10:38am
Around here its usually just called antique farm. Mine is pretty stock aside from a gov spring and a weight loss diet and a dry air filter setuo. I'm about 205 and I cross the scales at 3250. A lot of places this class is 3.5mph
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2013 at 4:34pm
i believe all the square seat A deeres would have done better in second gear . we dont usualy use creeper gear until 8500 - 10000.  The high/ low A did move pretty good but he may have changed out to the creeper gear  .
Post Options Post Options   Thanks (0) Thanks(0)   Quote cornbinder Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2013 at 7:39pm
a stock A doesn't have enough power to pull in 2nd
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2013 at 7:54pm
powerblocks are considered stock
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2013 at 5:21pm
heres a picture of a 10,000 lbs king of hill winning tractor at chatttsworth
THE-MAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote THE-MAN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2013 at 6:58pm
I love it.."we don't" ..."we this n that". Always figured Pank was a Deere guy just by his logic. Glad to be right, again.. Pank and that mouse In his pocket as they putt putt into the bs hall of fame.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2013 at 8:23pm
Pank has a allis's that he and his twin sons pull. Dads ole A pulls pretty well in heavy classes. Had to put a starter on it for him saturday so i slung some weights on it and told him we would find a pull this month to pull. His health hasn't been good i don't know if he can pull himshelf up on it but he grinned and said he would like that. when it won the king of hill we had 18.4/38s on it probably should put them back on her. Since the favorite pullers on here don't pull allis tractors i figured dads would fit right in
Edited by mlpankey - 04 Jun 2013 at 8:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2013 at 8:32pm
From now on, you need to pull that D17 in the low side of 2nd gear !!! That is 1/2 MPH faster than the high side of 1st gear. You cannot kill a D17 in low 2....never.
Rod B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod B Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2013 at 6:59am
Where can we see you pull your wd? You spent the winter telling us about your after Christmas 7" stroke build, your verry own crank and machine shop so let us know where and when to witness these hot rods in action.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2013 at 7:31am
This was the "A" class so you are supposed to pull in 1st gear, plus have stock weights. As you see the rules need to be enforced a little as the signup people put "B" pullers in that class.
Charlie
AaronH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronH Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2013 at 10:55am
two good runs. Congrats on the 2nd place. Good looking orange too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2013 at 6:55pm
the real question is where can rod be seen pulling . since he post no pictures of a shop or a tractor that he eludes he pulls
