water pump
Karl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Karl Quote  Post ReplyReply Direct Link To This Post Topic: water pump
    Posted: 02 Jun 2013 at 11:08am
hello, I looking for a part number or a source to get a water pump. Engine is a L or M combine engine that was used as a power unit for irrigation. has in line simms pump and has the long front to back oil cooler.   any ideas ? i can find pumps, but they don,t match what i have. 4006509 is the # i find for it.
James Coons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Coons Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2013 at 11:53am
The best way I have found to get the right pump is to get the casting numbers off the old one and match it up that way. Check the pumps that you do find to see if the difference is the hub just needs to be flipped or put the hub off the old pump on your new one.
Jim in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim in MO Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2013 at 1:36pm
I have a place they can rebuild our old pump down by Springfield, MO. PS I have a few used pump but need your casting # my off of M2-M3 660-527-3514 660-460-0419 C Jim
oilpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oilpower Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2013 at 8:34am
The pumping of water is a basic and practical technique, far more practical than scooping it up with one's hands or lifting it in a hand-held bucket. This is true whether the water is drawn from a fresh source, moved to a needed location, purified, or used for irrigation, washing, or sewage treatment, or for evacuating water from an undesirable location.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2013 at 9:38am
Reported 2
