Hd11e track adjuster
2wise4agm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Topic: Hd11e track adjuster
    Posted: 25 May 2013 at 8:44am
The seal in the track adjusting cylinder went out and now the track won't tighten. Do I have to split the track to change this, or is there another way? I'm not sure how far the rod goes in there, or how much slack I'm going to need to get it apart. Thanks guys.
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2013 at 10:06am
Track adjuster will come out without splitting track- you may have to block the idler, but you just have to lift the front of the adjuster after freeing it from idler pins, then the inner fork will come out past rear of idler and chain near the top.  There should be plenty of room when adjuster is retracted.  Seals are available from Henderson or Minnpar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2013 at 11:44am
That's good news. Thank you!
