Removing the Hand clutch....
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Topic: Removing the Hand clutch....
    Posted: 22 May 2013 at 9:43am
   I am going to remove the hand clutch from my WD. I need to loose the weight and also it has began to slip again. I am out of shims, so it's time for it to go. I tried all day yesterday to find a PTO gear to couple the shafts together. My local salvage yard doesnt have one "broke" to get one out of. He is in the middle of a clean up and said he would be at least two weeks before he could look for one. Searching the site for other ways I see where there is a coupler from Grainger that will work. Who has done this? does it work fine? The Grainger item # is 15V694. We pull this Saturday and then have a three week break, lots to happen in those three weeks... Help me out guys, I want to loose maximum weight, going to put sealed bearings in to keep from running oil in the housings. If anyone has something that will work they would sell let me know. I haven't ordered anything yet. I want to hear your opinions first.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
mattb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2013 at 12:33pm
theres a coupler on the back of a wc trans will work. throw the whole housing away if u put sealed bearings in it don't add any strength.
firephight View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firephight Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2013 at 2:24pm
Post some pics when you do your mod
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2013 at 7:01pm
have you tried jim cambell in lawrenceburgh?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2013 at 7:23pm
I have a coupler from a wc if your interested.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2013 at 7:50pm
  we have the coupler for a wd-wd45    call 1-574-342-4545 for info  just bolt it together
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2013 at 6:27am
mlpankey, Jim is who I was talking about.
bp4455 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bp4455 Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2013 at 10:28am
could someone please post a pic of this coupler. i found a junk rear and want to save this piece thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2013 at 11:20am
when you remove the battery box and remove the hand clutch  cover its bolted to the front clutch plate and slides up onto shaft. you will have to have yours and a donors and bolt the two together with the procedure already outlined to you on yt pulling forum . sorry i do not have a actual picture of the hub.
Post Options Post Options   Thanks (0) Thanks(0)   Quote firephight Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2013 at 9:24pm
saw some pics on your facebook page looks like the hand clutch held up for another weekend lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2013 at 6:02am
I bolted it, LOL!
Baldwinm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Baldwinm Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2015 at 11:33am
I have also been having trouble with my hand clutch slipping, Which part do I need off a WC to delete the hand clutch off of my 45? I have a WC parts tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2015 at 6:28am
There is a coupler that joins the shafts together. Pretty cheap to buy, go back sealed bearings if hyd. and pto has been deleted
Ken(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2015 at 6:58am
This will eliminate your slipping hand clutch, $58.00 delivered to your door.
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2015 at 4:06pm
Bought one of these and they are TOP NOTCH and very well built!
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
This page was generated in 1.008 seconds.
