Hydraulic Safty
roughstock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roughstock Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic Safty
    Posted: 23 Jan 2010 at 5:22pm
So I finally got around to changing my hydraulic oil today. I drained the pump and measured the amount I removed. After replacing the old oil with the new, I extended the rams to check the level. While raising the bucket to my loader, I got almost to full stroke when... POW... line blew and shot hydraulic fluid about six feet out. The bucket wasted no time falling to the ground. Luckily for me I wasn't standing near or under the loader arm at the time.  So monday I get to go buy a new line. Good times. Like my boss at work would say, "This is a good example of why we practice safe working habits."
Brian.
ToddSin NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2010 at 5:58pm
hey Brain how about replacing them all!
Post Options Post Options   Thanks (0) Thanks(0)   Quote roughstock Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2010 at 6:03pm
Money is tight this moth, but I will when the tax return comes, They are all pretty rough.
by moth i mean month
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2010 at 6:12pm
Seems as though it'd pay to develop the habit of never leaving arms, heads, feet or other body parts where something heavy can fall on/crush/pinch them.....imagine it's too easy to get complacent about the power of hydraulics....until they fail. Then it must get really exciting really quickly. Stay safe.............
WC, CA, D14, WD45
dannyraddatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2010 at 6:45pm
Brian,
Have they ever talked to you about a hydraulic line breaking and fluid getting under your skin. I always try to wear safety glasses and have seen the affects of the removal of hydraulic oil from under the skin. Always think safety when working around systems of any type. Please visit this site for a reminder http://www.dennismac.co.uk/hands/hyd/index.html
Danny
Edited by dannyraddatz - 23 Jan 2010 at 7:09pm
Danny Raddatz
Post Options Post Options   Thanks (0) Thanks(0)   Quote roughstock Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2010 at 8:10pm
Danny, I work at a foundry and we deal with a lot of high pressure hydraulics. Our furnaces' tilt is controlled by two rams that are 12" diameter and 10 foot tall. We also have push rams, high lows, and wedgers that all work under hydraulic pressure. I am amazed that this safety issue has never been addressed, considering the close proximity these rams work to molten iron. I am going to give this link to our safety coordinator. Hopefully we can implement hydraulic safety into our training course.  Thank you for the link.
Brian
r chancellor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote r chancellor Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2010 at 8:37pm
guys, if anyone gets a oil penatration don't fool around. go directly to the hospital, i've seen videos at work . It can kill you.
66 190gas, 49WF, b1, b10, 37WC, 48WF, B,C, 3 WD'S 66allcrop, 350chevy powered WC
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 7:46am
r chancellor i believe it will kill you if you dont take care of it. something else you guys should know and i am sure brian jasperco. knows this but the brake fluid from some of these abs systems on cars can inject the fluid in your skin and that will kill you if not taken care of soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 4:11pm
Yep, that is correct Bob. If you see oil squirting from somewhere, keep your hands away. Back when I went to trade school and we were working with diesel fuel systems, they showed us a short film on what happens when oil under high pressure gets injected into your hand. Not a pretty sight. Like R chancellor says, you go to the hospital right away and get your hand lanced open. If you don't, gang green can set in and you could face amputation.
One of the first demonstrations they did was with a diesel injector pop tester and an ordinary diesel injector. The instructor held a paper cup up around the injector tip and popped the injector. It shot through the cup no problem.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 4:25pm
Most hydraulic systems are failure rated around 2:1 like most other things. However, wear and use can take it's toll on hoses and other components so you never know when a failure can take place. The single most safety thing that anyone can do is not place thier body parts around something supported by a hose. There are pilot pressure operated safety devises made for cylinders so if you loose pressure the load cannot drop. The second safety issue is to not allow ANYONE to change the relief valve of a hydraulic circuit. The relief valve should be preset for maximum safe pressure for the engine, pump, valve body, lines, and cyl. as well as the metal frame of the component. Anything over that is just asking for trouble.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 4:35pm
The same goes for getting under something while on a jack. With the proliferation of cheap Chinese made jacks, do you really want to trust that they did their job right? I always put a safety stand under something jacked up before I get under it.
