pulling tractor
allismanamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Topic: pulling tractor
    Posted: 20 May 2013 at 2:37pm
I was wondering how many different makes came standard with a Chrysler engine I seen a wards pull and he went from the 3500 to 5500 # class and never ran out of power I have not seen many of these tractors but it sure sounded good.
I seen a CO-OP#3 ALSO THAT was a sweet looking tractor looked heavy though
Wonder what they put out for HP and what they are for cubic inches stock?
~AMP~
The Other Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Other Orange Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2013 at 3:47pm
The Wards HR had the 230ci flathead 6 and the ER had the 251ci flathead. I also had one with a 324ci straight eight. Massey 101 201ci, super 101 217ci. Lehr Big Boy 230ci. Most of these above can get in the 3500lbs classes. They all lack torque on a hard track the best option is the common 265 chrysler engine there good for 60hp in a tractor frame. I think the largest Coops had the 251ci but I could be wrong. 201,217,230 small block 23in heads. 251,265 big blocks 25in heads.
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2013 at 8:21pm
the 265 big block  makes good power stock. I know someone who put one into a Massey 101 super.  from a MH swather. It was rated kinda high like 70hp .
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2013 at 10:50pm
Would a cool e3 have this motor you think?
And can you shift the truck tranny on the fly like a ta?
~AMP~
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2013 at 11:04pm
Early Massy combines had Crys. engines also. Leon
This page was generated in 0.091 seconds.
