F-163 Overheating
razorsharp15 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote razorsharp15 Quote  Post ReplyReply Direct Link To This Post Topic: F-163 Overheating
    Posted: 20 May 2013 at 12:15am
I finally put the new head on my Acc-40 and now it won't stay cooled down. With three cracked combustion chambers its would stay cooled down until you really ran it hard. Now, idling, with the seat off, it gets hotter and hotter. New head gasket, head, & bolts (thanks Monte's Equipment) it won't stay cooled down.The radiator was cored prior to the head gasket going away and the thermostat was new just before the head gasket gave up. I'm running 50/50 mix coolant and there's plenty of hot air coming off the radiator. What am I missing here?
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2013 at 12:18am
Have you found out any more on your overheating problem? It may be worth taking out the thermostat and boiling it in a pot with a high heat thermometer to make sure it opens properly at the right temperature (I don't really trust cheap import thermostats). If the timing is too retarded you will also run into overheating. I've had two AC-40's and never had any overheating issues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote razorsharp15 Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2013 at 11:41pm
Boiled the thermostat, its fine. Did a temp check on the upper and lower coolant hoses, they were within 15 degrees of each other, not much hot air was coming out the back end of the forklift. The end of the head where the temp gauge sender is, was running at 220 when I shut it down.  I used a portable heat sensor to check temps in various areas and the head had "hot areas" and the back end of it was the highest for sure. The water pump is suspect, but, it doesn't leak nor does it make any evil noises
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2013 at 5:04am
Water pump might not have any fins on it.  Sometimes rust just eats 'em up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote razorsharp15 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2013 at 7:34pm
After many weeks, I have an update: Ordered a new water pump, got the wrong one. In the meantime, got the old one out of the forklift and pulled it apart. The impeller is complete and working. No leaks past the seals, the bearing seems alright as well. Now I'm really stumped. Seems as though the coolant system gets hot but I see really no circulation of coolant. Thermostat tested good, water pump has a functioning impeller, now I'm at a loss on what to check next. Ideas?
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2013 at 10:21pm
Did you turn the head gasket around so it may have blocked water flow. I am told it can be done to some of the old AC engines
Post Options Post Options   Thanks (0) Thanks(0)   Quote razorsharp15 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2013 at 5:52pm
I've pulled the head loose and verified that the gasket was on correctly. This one doesn't appear to be able to go on backwards or upside down. While I have the radiator out and can see in there, going to make sure to get the timing right. Also, may buy a electronic kit to replace the points and condenser. Once the new pump is on, I'm planning on running a coolant flush through it to try and alleviate any scaling and rust that may be lurking within. I did replace the plugs and oil as well. Going to check all my valve clearances while its apart too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2013 at 8:42pm
It still sounds as the engine is air bound, you will need to add a vent valve before the thermostat to verify the block and head get full of coolant, AC put one on my 7G crawler engine to vent to confirm full to get coolant to move around. And no, just running a engine may not move the air pocket out, ask any Ford 7.3 owner, we also have to vent the system to get a complete fill.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2013 at 11:47am
Is the lower rad. hose collapsing?   Leon R
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2013 at 1:02pm
I would also agree that the engine is air bound. I have a Jeep Comanche pickup with the 4L engine and it is really challenging to get the air out of the engine and circulating properly and it acts the same way. This may have been a problem in the past and may have caused your cracked combustion chambers. I helped my son change a water pump on a Dodge Caravan and it took forever to get rid of the airlock and circulating properly.
oilpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oilpower Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2013 at 8:23am
Overheating of an economy occurs when its productive capacity is unable to keep pace with growing aggregate demand. It is generally characterized by an above trend rate of economic growth, where growth is occurring at an unsustainable rate.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2013 at 9:40am
reported 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote razorsharp15 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2013 at 4:09pm
The saga continues onward. Still working on getting a proper waterpump/pulley combo that fits. Whole different issue. I did however, pull the block drain on the right side of the forklift and it was clogged. Cleaned it all out and now wondering where I should start for purging air from once I get the new pump installed. There are several plugs in the top of the head, including the coolant temp sender. Should I crack those as it runs and attempt to burp it that way?
And to answer a question from a previous posting, no, the bottom hose has not collapsed. It has the metal liner/spring deal in it so it is damn near impossible to pull closed. And not very flexible either.
It was recommended to me to run a 50/50 mix of Simple Green and water to alleviate the grease, grime, scaling, rust, etc before flushing out and refilling with coolant. Thoughts, ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2013 at 4:32pm
If you have the thermostat "cap" off (where the upper rad hose goes on) and you see a tiny hole in the thermostat, that is there to let air escape to the top....if there is no tiny vent hole use the smallest drill bit you have and drill a hole in it. Beyond that you don't have to pull any plugs to fill the cooling system in order to get the air out. Once the engine runs for a few minutes turn it off and top up the radiator if it needs it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2013 at 5:15pm
My 3500 in the 7G has a bleed screw in the t-stat housing, on the engine side of the t-stat. If your housing has a plug in it I would highly recommend a replacement pet-cock drain as goes in most cooling systems, fill and vent until all the air purges, then completely fill and test run. The older diesels and many older gas engines were very prone to air binding and I don't agree on the bleed hole drilling. I have seen it done and work but also seen it done and the engines ran cold.
Post Options Post Options   Thanks (0) Thanks(0)   Quote razorsharp15 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2013 at 1:17am
There is a tap that comes off below the thermostat itself where coolant gets diverted to the propane regulator to heat the propane. Wouldn't that let the trapped air go back through the cooling system and be "burped" automatically? I have finally gotten a proper pump, getting another belt, drilled a hole in the thermostat as suggested, so should have a report soon and hope that its fixed. Anyone have a thought on electronic ignition replacing points and condensors?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2013 at 12:11pm
Electronic ignition is the way to go. You can pretty well set it and forget it except you still have to lube the distributor shaft bearing occasionally as recommended maintenance. Hotter spark and no wearing parts to replace that fail or alter timing. You may have to change the coil as well if it doesn't have the correct resistance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote razorsharp15 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2013 at 8:22pm
Having to redo the gasket on the pump as it was set on slightly "cockeyed" before i got it. Thought sealer would work, was not the case as I proceeded to pump water in all directions. Now to disassemble and try again. Also, seems like the alternator has fried too. When it rains, it pours. Just go with a standard GM replacement or is there another winner?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2013 at 11:16pm
The GM - Delco alternators are the most reasonable and usually last a long time. O'Reilly Auto Parts have them at a good price. If yours has fried you better make sure there isn't a short somewhere or you may lose the next one you put on too.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2013 at 9:16am
I haven't worked on one of these forklifts, but the problem you've described vexed me on an engine a while ago... everything appeared to be perfect... and no matter what I did, I couldn't get it to cool.
Most older equipment was designed with the cooling system oriented so that air pockets couldn't appear in critical places... BUT...
There are areas where the manufacturer included passageways and holes that allowed air to exit upwards.
Since you found corrosion crud blocking a drain plug, I would be most suspicious of other places in the block having same problems.
The solution, is to drain the engine, yank the head, and anything else that grants you physical access to the block and head.  Get a piece of woven piano wire about two feet long, a coathanger, a bicycle spoke... a piece of a MORSE push-pull control cable... whatever you can find... (I use my old guitar and bass strings!) and chuck it in a cordless drill, and run it down every coolant orifice, through every passageway, and to every nook and cranny... every lower corner of every cylinder jacket... let it fray and scrub the crap out of everything.
Next... hose the inside of the block out.  Yeah, you'll get water in the cylinders... it won't hurt anything, vacuum it out.  if there's oil passages through the head gasket interface, you'll have water in the crankcase... drain it out.  You'll see crud from the paleozoic area come out... rod it some more. keep rinsing and rodding 'till you're sure the water coming OUT is cleaner than what came IN.  Now rinse the radiator... flow water in backwards (opposite normal flow).  Set it on a table, and vibrate the table (sawzall with no blade, bench grinder with slightly chipped wheel, something like that), then rinse it again.
Then dry it out (shop-vac is your friend!) and put it back together, try it again, and either cuss, or cheer.
I doubt you'll have to cuss... Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2013 at 9:19am
By the way... if your prior head had three cracked combustion chambers, I'd be willing to bet that those chambers leaked compression gasses into the cooling system.  By doing this, probably caused your cooling system to perpetually vent, and most likely, kept the coolant in a boiling-loss state, close to atmospheric pressure.  Since water boils at a fixed temperature and pressure, it can be used just as it is... as  a very accurate thermostat... that's how hopper-cooled hit-miss engines managed to self-regulate their operating temperature.  Unfortunately, having a compression leak INTO the cooling jacket causes the radiator cap to relieve, hence, boil, and as a result, the engine 'seems' to stay cool.  It probably wasn't... it just didn't seem like it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote razorsharp15 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2014 at 12:30am
Well, that battle is over. New pump, new thermostat (with courtesy hole drilled), complete flush of the cooking system, and we have a solid system with no leaks and stays under 190 degrees.
I have also ordered the Pertronix electronic conversion for the distributor and a new coil for good measure.
The hydraulic pump on the tail end of the forklift has quite a whine. Should I be concerned? Still working on getting the brakes to function, solving a few hydraulic leaks. Also, does anyone know what the proper capacity of ATF for the transmission. I can't find a proper spec nor whether to check it while running or shut down.
But for now, its usable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2014 at 11:07pm
Make sure that the hydraulic pump isn't sucking air from somewhere... and furthermore, isn't recirculating aereated oil... air bubbles in the oil generate incredible amounts of heat when the hydraulic pump squishes 'em down by a factor of 20...
Post Options Post Options   Thanks (0) Thanks(0)   Quote razorsharp15 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2014 at 7:58pm
If air is getting sucked in somewhere, wouldn't fluid leech out where air was coming in? I am going to get several of the hoses changed as they are a bit old and the outer rubber is coming off. Could it just be a 30+ year old pump whining its last?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2014 at 5:59am
Not necessarily, the shaft area of the gears in a hydraulic pump tends to run in a vacuum as the gears draw fluid from the inlet and deliver to the outlet they can draw air there or at the seal ring for the suction and not leak when the engine or pump is turned off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote razorsharp15 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2014 at 11:42am
Is there a way to check for possible air in the system? Should I have the pump rebuilt (i.e. new seals, etc) and just eliminate that possibility? I do hope to make this unit bullet-resistant as it'll never be bulletproof.
