7g=b loses ttans pressure |
edwin
Joined: 06 Apr 2013 Location: lebanon mo Points: 49 |
Topic: 7g=b loses ttans pressurePosted: 18 May 2013 at 10:39pm |
just bought machine. sometimes has trans pressure for 30 seconds . other times no pressure at all.all suggestions welcomed. Wher might ther be screens or filters ..thanks for your time.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35682 |
Posted: 19 May 2013 at 6:07am |
7G B has a similar trans screen to the 7G, in the main trans case where the steering and main trans pump suction lines attach is a flange bolted to the face of the trans, drain the trans, remove the flange, on the backside attached to the flange is a permanent screen filter. As to the remaining filters I am not up on the B series, there should be filters for the steering and the trans in housings in-line to those systems. On my 7G the steering filters were behind a panel aside the shifter while the trans filter was hanging between the trans and the torque converter.
