hd21 craigslist
michale34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Topic: hd21 craigslist
    Posted: 16 May 2013 at 11:22am
craigslist 3803057313 heres  a hd 21 price seems steep to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2013 at 8:38pm
Kinda hard to look at it without a site address, the CL number doesn't go anywhere in particular.
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2013 at 9:11am
sorry craigslist little rock ar
James Coons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Coons Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2013 at 9:19am
Here's the link
http://littlerock.craigslist.org/grd/3803057313.html
It is very high I think, Missing Radiator, torched track. Maybe they'll come down on the price with some coaxing. If it helps save it I do have a good radiator, hood, and a few other odds and ends that will fit it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2013 at 4:52pm
I think i heard some talk about this tractor a few years ago .I heard of a hd 21 that had a cutter blade on it that was in a patch of woods in that area that someone had shot holes in the radiator . the machine suposely had trouble with the final drive  and was parked I dont know if this is the same machine or not but with the radaitor missing and a track cut it might be . or on the other hand scrappers my have taken the parts but the exhaust is covered and the air cleaner is on so i would think scrappers would just leave it uncovered.I might take a ride and look at it . its only about 80 miles from me.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2013 at 10:15pm
looks like an early model 55-58 Buda/Lanova with HD844 and mechanical blower similar to detroits before the use of turbos
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2013 at 12:07am
What do you think it was used for?  Kind of unusual to have a winch and no blade.  Can't see $8,500, maybe $3,500.
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2013 at 6:27am
could have been used to pull scrapers with dual spool rear cable unit, or more likely blade was removed to tilt nose/remove radiator and sold/scrapped/lost. yes quite high for not running and no blade.
they are hard to load when they don't run.   doesn't run = no hydraulic power = no steering
even pulling it around with a similar size machine is a challenge. have done this with HD16s
Edited by CAL(KS) - 18 May 2013 at 6:30am
This page was generated in 0.208 seconds.
