New fork Lift
Channel_Seedsman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Channel_Seedsman Quote  Post ReplyReply Direct Link To This Post Topic: New fork Lift
    Posted: 13 May 2013 at 4:43pm
Brought this home Friday. FTP 40-24 S.N. 18898000, not sure of the year yet. The tilt cylinders leak and brakes dont work to well but other than that it seems to be in good shape. I would like to get a operators/service book for it, any ideas where i could find one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2013 at 4:46pm
That's cool, nice find
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2013 at 5:42pm
komatsu dealers can get you a new op manual and i think a service manual but they don't like doing it and they take a long time.
looks like about a 1970 or so
be carefull if you pull the brake drums...i think that will have the bull gear type axles and the gear is in the drum. they're HEAVY
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2013 at 7:20pm
I second that about the drums !!! My forklift (AC of course !) only has singles up front but tire/rim/drum is very,very heavy.If you have access to a proper 'tire installing jack' great !! getting off is ok but to install you gotta be dead level and straight !!!!
trick I was told was to tilt mast all the way back,put 6by6 or bigger under mast, move mast forward.that'll raise the front off the ground just enough to get wheels off the ground.
hth
jay
This page was generated in 0.168 seconds.
