HD6E engine swap
mahto48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mahto48 Quote  Post ReplyReply Direct Link To This Post Topic: HD6E engine swap
    Posted: 06 May 2013 at 12:43pm
I have a second stage buda 344 engine in my HD6E and would like to put an AC 7000 turbo charged 344 cubic inch military surplus motor in it. The blocks look identical with different attachments. Can anyone advise me of the ins and outs of this swap.
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2013 at 12:04am
I,m lookin at doing that. So far, I can see I need to swap sump, flywheel and housing, timing gear housing. To get accessory drive for fan, dont yet know if drive in front of American Bosch pumps can be used with the Roosa pump on the military engine, or I gotta use the Ambosh fuel system to make it all work
Post Options Post Options   Thanks (0) Thanks(0)   Quote mahto48 Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2013 at 10:27am
I was trying to find a crank for my HD344 but people that have them seem to think they are made of gold. I can buy a complete running 7000-344 cubic inch for less but I do have some concerns about the accessory drive and the fuel system. I am working to solve this puzzle before I spend the money for the 7000.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2013 at 11:26pm
The 516 engine in HD11 tractors is same as 344 with two more cylinders. The second series of wet steer HD11 had Roosa pumps with accessory drive for fan. I,m just not sure if you can swap the fan drive off the American Bosch setup to Roosa. If you could just get a fan drive off one of those Roosa pumped HD11 tractors, would not have to worry about interchangability
ac_sd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_sd Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2013 at 2:02pm
I had previously been told that the 344 Buda engine and the later 6000 sereis engine used the same crankshaft.  This should be fairly easily confirmed by checking part numbers ( AC did a complete  part number change somewwhere along  the way, so that needs to be factored in). Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mahto48 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2013 at 11:14am
I have checked the crank casting numbers for the 6000/7000 344 cubic inch motors and have found them to be the same. I think I will go ahead on the surplus 7000 motor and if it doesn't bolt in I will at least have a crank I can use for a reasonable price. Any input about  is appreciated .Confused
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2013 at 11:30am
I have 4 or 5  crankshafts for 344 let me have your parts number
Post Options Post Options   Thanks (0) Thanks(0)   Quote mahto48 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2013 at 2:22pm
The casting number on this hd 344 is 4348425. Crankshaft application sheet shows additional numbers 43448399 & 434525 for this crankshaft. The 344 ci 6000 allis chalmers gives the following numbers, which should fit the 344 buda. The dimensions are the same.
4354423, 4354426, 4357331,4359794, 4359796, 4359873 & 435987. It needs to clean up at 0.020 or if necessary I can get 0.030 bearings.
Thanks for your input
Post Options Post Options   Thanks (0) Thanks(0)   Quote mahto48 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2013 at 4:40pm
Sorry: The second crankshaft number should read 4348399
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2013 at 5:55am
I check and have 2 crankshaft with # on 4348425 and one is 20-20 and the second am't sure if it .0020  or .0030 and have 2 crankshaft 4357995? no sure for the last 3 initial # and they look standar and find no cutt # on
This page was generated in 0.181 seconds.
