Advice for changing fan belt on WD45
troy(el paso, il) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote troy(el paso, il) Quote  Post ReplyReply Direct Link To This Post Topic: Advice for changing fan belt on WD45
    Posted: 05 May 2013 at 3:52pm
Hello All-
Just noticed my fan belt is starting to fray on my WD45, time to change, any pointers would be gladly appreciated.....Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2013 at 4:19pm
Drain the radiator and remove the lower radiator hose at least on one end to get the fan belt to go by it. You have to remove the lower radiator hose...no other way.
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2013 at 5:35pm
it is a good time to just replace the lower rad hose while you're at it.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2013 at 5:51pm
Don't forget to shut the engine off first!!  Tongue  Sorry couldn't resist!
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2013 at 8:32pm
Really is easier to get ya a new lower hose and just cut the old one off
Jake9798 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake9798 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2016 at 12:54pm
How do you get it around the bottom pulley? My has a hand crank so there is no opening to slide the belt off..
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2016 at 2:16pm
The hand crank rod that goes through the steering gearbox has a spring on it. It should be about 1" away from pulley unless you push on the rod to engage it into the pulley. When you stop pushing the rod flies back to home 1" away.
