WD Engine Question |
Osage_Orange
Topic: WD Engine QuestionPosted: 21 Jan 2010 at 8:05pm |
What's the purpose of the plate on the right side of the upper part of the engine block? (I'm talking about the one that was eliminated on 45's) What does a person see if the plate is removed? Why would the plate ever be removed? Thanks for the education............O_O
NCWC
Posted: 21 Jan 2010 at 8:23pm |
I beleive that the tops of the lifters and the pushrods would be showing if you removed that plate.
B,C,CA,RC,WC,Unstyled WC,WD,WD-45,B puller, WC Puller,WD Puller, WD-45 Puller
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 21 Jan 2010 at 10:02pm |
Yep.
alliswd
Joined: 02 Jan 2010 Location: EC Wisconsin Points: 26 |
Posted: 22 Jan 2010 at 12:22pm |
My belief is that - at the time - the casting capability of the thin core required between the cylinders and the "plate" was not able to withstand the pour. So they tied the core into the sand outside the block thru the big hole that the plate covers up, so that it got the support it needed. When the technology improved ( probably better binders in the sand ), they where able to remove the plate and cast the outer wall inplace. Just my hypothesis...
Jordan(OH)
Joined: 11 Sep 2009 Location: Celina, OH Points: 1569 |
Posted: 22 Jan 2010 at 12:59pm |
There is no "hole" that the plate covers up, all you can see is the pushrods.
CTuckerNWIL
Posted: 22 Jan 2010 at 1:05pm |
Jordan, I believe Dean is talking about the large cavity that push rods go through. The same cavity that the plate covers.
