tire recomendations?
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Topic: tire recomendations?
    Posted: 29 Apr 2013 at 9:36pm
Restoring a unstyled wc for show and stock pulling. I have styled type 28 inch wheels on it. I currently have a nice set of older firestone 45 degree tires on it but they are only 12.4s. I was thinking of going with 13.6 or 14.9s. I have 55 hp to pull them with, 3500-4000 lb. classes. Should I even try pulling the 12.4s? What size do you recommend? What brand? Pulling in ohio clay. Firestone field and roads are gone, now they have sat2, are these any good? Thanks for any info, JM
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2013 at 6:23am
There is lots of tractors around here running a stock e3 gleaner engine with 15.5x38, in FARMSTOCK, LOL, go figure...
   They handle them well.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2013 at 8:04am
How can you use 38's in Farm stock?
Charlie
mattb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2013 at 9:19am
most clubs allow 15.5 38s in super farm stock how fair would it be to have to run 28s when most other brands came with 38s?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2013 at 10:06am
Super Farm, OK
Farm Stock no. The tractors came with what they came with. If you want to run 38's then buy a brand that had them
Charlie
bmartin55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmartin55 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2013 at 3:58pm
wd had the opution to order 38s on them in my book..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2013 at 5:29pm
Cool, can you scan that? Argument at the club was Allis  never had that option for WC/WD's
Charlie
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2013 at 6:39pm
WC, s were never offered with 38" tires . 36" were the tallest tire offered from AC.  Wc tractors with 36" tires were high crop models and had a lower final drive ratio to keep speeds close to standard WC speeds. In the reference books that I have  checked , wd, wd45 tractors never had 38" tires , it wasn't until  the D17 that AC offered a 38, and  a 13.6X38 was the largest available.  I'll consult other references in my tractor book library to confirm., and if I find 38's for wd, wd45s listed , I'll repost.
Edited by Gary in da UP - 30 Apr 2013 at 7:00pm
YT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote YT Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2013 at 9:10pm
Our original owners manual for our WD-45 shows 38's as a option.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2013 at 9:25pm
WD's and WD45's have 38's listed in the parts book !!!!!!!!!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2013 at 6:29am
Great, can someone scan that for me? I need proof to show the rules committee
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2013 at 1:02pm
Duh ! , I have parts books for all these models, never gave it a thought to check them, sorry for the omission !
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2013 at 2:50pm
doesnt matter for my association, i can only go 2.5 max on farmstock, super farm is 8mph but that is like really serious. way to much for a stock wd, guess how fast first gear is with 28 inch rims on a stock wd, no room for bigger tires
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2013 at 6:37am
Unless you've changed gearing or have lots of low end torque, 38's on a WC won't do well for 2.5-3.5mph class....its tough with stock gearing and 13.6x28's to keep slow. I was all for a set for mine till I pulled awhile and watched a lot....16.9x26 I think will do me well. Short and fat....doesn't mess up my ground speed and gives me lots of footing
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2013 at 7:20pm
Most of the pulls i have pulled at have a line somewhere down track that you can speed to before the speed limit is enforced most  of the time its at 100 feet  . Blow the horn 99 feet silence it at 100 and the sled by then will usually have caught you enough that your not going regain your speed with tall tires unless the engine has a lot of snot in  it.
