block heater for 190 gas
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: block heater for 190 gas
    Posted: 21 Jan 2010 at 4:17pm
Does anyone know where I could find a soft plug type engine block heater for my one-ninety gas? (not an XT)  Thanks in advance    Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2010 at 6:15pm
Ive had good luck at auto parts stores, measure the freeze plug hole ,they have various sizes ; I got lucky on my 190 , it had the 2 holes in the head casting like a 185 has to put a plug heater for a 185, its on a square plate and you bolt it to the head, I had to reroute the fuel line a little but it was worth it   ;or you can put a tank heater on it , it mounts on the frame and you have to use heater hose; it works !!!
PBSoMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PBSoMd Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 4:38pm
Our Napa dealer has a book with most 100 series and above listed. You can order just the plugs  if that's all you need.
