720 drive shaft
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: 720 drive shaft
    Posted: 25 Apr 2013 at 12:45pm
My brothers 720 vibrates in the back and he thinks the driveshaft is bent (It does have a wobble to it). He had replaced the flex coupling when he had it apart, so that should be ok. Any other ideas?
Any other way to remove it without moving the engine?
Any used ones out there? I had heard at one time that other brands (Other than Powermax) might match up as it was a common shaft
Charlie
aras View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aras Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2013 at 2:34pm
I took mine out and straightened it in a press.  I was able to remove it after the cover on the middle section is removed on the topside.
The coupler needs to be checked for runnout when installed on the engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2013 at 2:44pm
Can you explain what you mean by runout?
Charlie
aras View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aras Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2013 at 3:28pm
The shaft must be concentric to the engine pulley....  I'll see if I can find the service manual
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2013 at 4:36pm
Runout is how much wobble the shaft has, in laymans terms if the shaft is bent or tweaked it will wobble
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2013 at 5:58pm
Charlie, also check that it was re-assembled correctly.  I always mark a shaft, with paint, on each part, and U joint.  If the U joints are out of phase, that will vibrate like crazy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2013 at 7:10am
Thanks for the help!
Charlie
