OT jd 410b backhoe reverser problem
cob_crusher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cob_crusher Quote  Post ReplyReply Direct Link To This Post Topic: OT jd 410b backhoe reverser problem
    Posted: 25 Apr 2013 at 10:30am
have jd 410b backhoe. forward works aok in all gears. reverse does not work in any gears. service manual shows port where to test pressure but does not give normal oper
range. anyone know ?  dealer says bring it in.  before i rebuild control valve is there a test to verify that this is problem ? how can i manually move spool valve to make sure it
is not linkage ?  disengage and move and check ?
ac 200 7080 653 da d90.06 6265 f400 ol 77 1650 jd 4230. the reward of suffering is experience. ignorance is bliss. no muff too tuff. i am only responsible for everything. free whiskey naked women.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cob_crusher Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2013 at 7:30am
took apart mechanical linkage for forward / reverse dash lever. manually put in reverse position. worked aok. readjusted linkage. works fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2013 at 12:08pm
glad you found a easy fix to the problem.
This page was generated in 0.313 seconds.
