its fire up time
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Topic: its fire up time
    Posted: 25 Apr 2013 at 8:23am
so i have my c ready to fire up and i want to make sure that i have the wires in the right spot. i have the big wire from the alternator going straight to the positive side of the ampmeter. then a wire from the negative side of the ampmeter to the positive terminal of the battery. correct so far guys?
next i have two toggle switches. one for the lights and one for both the signal wire for the alternator and the other wire goes to the coil. the signal wire has the resistor in line. so far so good?
well to power the two toggle switches i took two short pieces of wire and come off the battery side of the ampmeter and run one wire to each of the toggles.
i just want to double check before i hook up the battery. easier now to change some wires then down the road replace parts.
thanks guys
