cut tires worth it?
farmer_rob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Topic: cut tires worth it?
    Posted: 21 Jan 2010 at 8:03am
im looking to purchase a set of 14.9x28's on blank steal rims to get away from the weight of the power adjust. they look to be about 70-80% with new tubes and they are also cut.. should i stay clear of cut tires with a stock wd45 for pulling.
thanks
if farming was easy everybody would be doing it
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2010 at 8:48am
Check yours rules because around here if you have cut tires you can't pull in the farm stock class,you will be pulling your stock WD against the big boys.
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2010 at 9:09am
around here they can be top cut in most classes
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
NCWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCWC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2010 at 9:51am
Wd-45 with topcut 14.9's you shouldnt have a problem if your tractor is spinning out now with 14.9's now what weight class are you pulling 3500?
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2010 at 9:56am
yes my tractor is spinning out now.. i havent run 3500lbs class yet but ill do 2 or 3 of them this summer.. i mainly run 4000/4500/5000/5500. in the 4-4500 im right at the top but the 5-5500 im in the middle of the pack of 18-20 tractors.
NCWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCWC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2010 at 10:07am
The topcuts will definatly tell you what kind of engine you have in the heavier classes. We run 38inch wheels, I know for a fact that if you topcut 38's you better have some motor. Our club allows topcuts and they do help with grip on a harder track.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2010 at 1:01pm
How do you cut tires? I have one that's out of round, I'd like to see if I could true it up.
Dusty
Ken(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2010 at 1:23pm
A power wood planer does wonders Dusty, just make sure it has sharp blades in it. I have a Bosch just for cutting tires, pretty hard to beat, especially if you have ever done it with a grinder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2010 at 1:31pm
Ken,
I'm in Florida now, Home is half way between Charlotte and Grand Ledge. Maybe when we get home I'll see about you helping me.
Dusty
NCWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCWC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2010 at 6:59pm
Where are you from Dusty?
B,C,CA,RC,WC,Unstyled WC,WD,WD-45,B puller, WC Puller,WD Puller, WD-45 Puller
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 9:26am
I know right where you live Dusty, at the end of Doane HWY, just down the road from Dills. I'm living in Holt now, but give me a shout, I still get out to the old neighborhood quite often, and would be glad to help you out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 10:23am
NCWC, Zephyrhills Florida right now.
Dusty
