M&W pistons?
mufflerboltz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mufflerboltz Quote  Post ReplyReply Direct Link To This Post Topic: M&W pistons?
    Posted: 20 Apr 2013 at 9:03am
are the m&w pistons any good? found a set of 4 1/8 bore for cheap
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2013 at 10:14am
  They ran a taller compression height than others and had a larger dish in them.  That dish is right near 70cc in both the AP46 and AP48 pistons, they just changed the wrist pin height for use with a 4" crank or a 4.5" crank.  The wrist pins are offset close to .100" for a better rod angle.
A new ring set is fairley expensive as they take an extra ring but the set is available from Hastings.  I bet you could use a cheaper set of the right size rings and just skip one of the compression rings with no problems...... it's likely better if you did as there's to many rings on them anyway.
I put a set of ones from a 4" stroke (WD-WC) engine in a Gleaner E engine (4.5 stroke) , trimmed the tops to pop out of the block and give a quench.  I cut the bowls out to relieve the compression down to a reasonable ratio and cut some valve reliefs in the tops.  Stock cam set at a 105* intake centerline and the engine sure lugs good for what it is.  Quench is important, keeping a piston down in the hole so far isn't the best solution, they give up some torque and are prone to detonation but it's usually all we have to work with in these engines.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2013 at 10:18am
If I found a good set of M&W pistons cheap, they would be going into one of my WCs pronto! Of course you will need to find a good set of 4.125" sleeves and pony up for the little bit pricey rings. If these are the WC/WD version you will end up with a 217 cid engine and if they are for the WD45 or some other 226 cid application you will end up with  240 cid. I'm just a sentimental sucker that likes the old school performance builds like you could get from a decent dealer back in the day!! Kip
