Could this work as a D-19 tach drive?
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Topic: Could this work as a D-19 tach drive?
    Posted: 20 Jan 2010 at 12:54pm
I am looking for a tach drive for a D-19. I thought I remember someone on here telling me that Chevy trucks had the same style Tach drive. anyone else know?  ..Look at the bottom of this posting..I posted a website.
Edited by Austin(WI) - 20 Jan 2010 at 2:13pm
"Better By Design"
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2010 at 1:14pm
I am also looking for one. Yes hopefully something cross matches, I am sure that Agco wants high dollar for one..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2010 at 1:24pm
you bet they do! $150
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2010 at 2:05pm
This is from a 1965 Corvette. Is the the same as the D-19's?
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2010 at 2:09pm
Here is a website...$29 I have no clue if this will work...any input would be awesome.
"Better By Design"
Bob(FL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob(FL) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2010 at 2:16pm
I can't remember what mine looked like, but the tach drive runs off the oil pump and the oil pump has the gear, think mine had a blade that went into the oil pump.
Brad-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2010 at 2:17pm
You guys have to make sure that it's actually the small gear you're showing is all that's bad in there.  Mine had a good cable drive, but the distributor gear was worn completely smooth.  I went out and bought a replacement gear from AGCO for big money, put it in and still no tach...my own stupid fault I guess...lol.
1930 U
1938 A
1941 WF
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob(FL) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2010 at 2:21pm
Sorry, mine is a diesel, could you use a set up fron a diesel, same as a d17 diesel.
