clutch
allispuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Topic: clutch
    Posted: 17 Apr 2013 at 7:38pm
was wondering how much hp a nine spring button clutch will hold before it will start slipping. I was thinking about putting one in my WD45 pulling tractor I'm in the process of finishing up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2013 at 7:52pm
 9 spring WD45 pressure plate with a FOUR button (on a side) from a K-K2 Gleaner combine will hold 100 HP alright. What have you done with your hand clutch??????????????
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2013 at 7:54pm
I have not done anything with my hand clutch. Any suggestions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2013 at 7:55pm
Yeah.....remove it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2013 at 7:59pm
what is the reason that removing it is always suggested
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2013 at 8:38pm
If it is eliminated, there is zero chance of it slipping, plus you can loose maybe 30 pounds of weight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2013 at 8:43pm
what is involved in eliminating it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2013 at 8:52pm
Tractor has to be split underneath the battery box. Once the hand clutch assembly is unbolted from the PTO drive gear, you'll see that if you had a second PTO drive gear (even one with gear teeth missing) you could easily bolt the two together with bolts and locknuts and roll it back together. Problem solved. Now you can remove the hand clutch lever for more weight reduction.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2013 at 9:03pm
so from what I'm gathering is that I just need to remove the clutch assembly and find another pto drive gear. and it doesn't matter if it is missing gear teeth and bolt it to the existing pto drive gear and bolt it back together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2013 at 9:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2013 at 9:11pm
That is what I do with any WD Puller. Use Grade 8 bolts......and you will see a lip or flange on each gear for the hand clutch to pilot onto. I always grind the lip off of both gears so they fit tight together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2013 at 9:15pm
so if I remove the hand clutch would a stock nine spring pressure plate and a button clutch hold up to 100 hp
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2013 at 9:22pm
A FOUR button disc (4 on a side)....not six or eight or whatever some clutch builder thinks is a good idea.  And four small size buttons, not huge ones.  Even three buttons would be fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2013 at 9:26pm
thanks for all of the help I truly appreciate it. where is the best place to find a four button clutch
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2013 at 9:29pm
An AGCO dealer who sells parts for AC tractors or Gleaner combines will fix you right up......K or K2 Gleaner combine clutch disc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2013 at 9:31pm
thank you for all the help any idea on where to come up with the pto drive gear if I decide to remove the hand clutch
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2013 at 9:34pm
A tractor salvage yard (junk yard).
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2013 at 9:35pm
thanks I will look into it you have been a real help
This page was generated in 0.104 seconds.
