Getting a D19 gasser to the 5000 lb class
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: Getting a D19 gasser to the 5000 lb class
    Posted: 14 Apr 2013 at 7:23am
Anyone ever get a 19 gasser in the 5000 lb class ? Im thinking itd be pretty tough?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2013 at 7:28am
Not a problem, there is  alot of cast to take off.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2013 at 7:38am
Very true, steel wheels would make a big difference , with that and no 3 pt housing get it there tho?
Edited by DougG - 14 Apr 2013 at 7:54am
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2013 at 11:33am
I pull my 19 diesel at 5000 wide front
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2013 at 11:46am
What did u get it down too?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2013 at 12:21pm
A wide front would be too heavy most of the time to ever have a prayer of "balance" in a 5000 lb class.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2013 at 12:42pm
True, lose the original balance and its over, i tried that with a 190 , stripped to 7000 , itd spin out way to easy, too much front weight
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2013 at 12:47pm
System front end d14 spindles non adjustable 2000 lbs front 3000 lbs rear
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2013 at 12:58pm
Now, the truth comes out !!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2013 at 1:22pm
In fact, the one we had 20 plus years ago had a D17 NF pedistal to lighten it up more and move the front end down a bit over the stock D19 pedistal, which was taller. It was still nose heavy some of the time  in a 5000 lb class with 18.4 x 34 pressed steel on the rear.
