leroi heads
farmer_rob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Topic: leroi heads
    Posted: 19 Jan 2010 at 8:15pm
i was talking to a guy this morning and he claimed that the heads that were used on these engines when mated up to air compressors had higher compression.. is this right?
if so where could i find one
thanks rob
if farming was easy everybody would be doing it
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2010 at 8:30pm
I have a lerio centaur tractair complete . they are like my sullair with the 192 industrial ford engine the air is drawn into the compressor and intake through the same filter but i dont think that affects the compresion ratio . now if the carb was on the 100 psi 125cfm side it would have a affect as in boost.
