WD valve seal installation?
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Topic: WD valve seal installation?
    Posted: 19 Jan 2010 at 6:43pm
The valve seals (and maybe valve guides) are leaking in my WD.  Gonna' replace the seals with the head still installed on the tractor tomorrow.  (I've done this on cars many times.)  Are there any secrets that are unique to the WD when doing this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2010 at 6:45pm
There are no valve seals on a WD engine unless somebody added them. If you are sucking oil through the guides, the guides probably need replaced.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2010 at 7:01pm
Interesting! There are rubber seals directly above the surface of the head.  Due to the amount of work involved, I'm gonna' take a shot at replacing what is there.  May work or may not.  I don't know what is keeping them in place.  Will check it out tomorrow.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2010 at 7:19pm
Osage orange usually they dont have valve seals. most just have a plate that shields the valves from oil goes right over the four bolts that hold the rocker stands and valve cover . I personally prefer the valve seals and add them to every new head I do. The reason is I have had better luck with valve springs that have some oil going to them even though most springs fall off 10 lbs on first few runs the one lubricated seam not to fall off as bad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2010 at 10:39pm
I'm anxious to get another look at that head.  Can't figure out what holds the seal in place unless the seal outer diameter is large enough to somehow bind on the valve spring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2010 at 10:46pm
I wonder if the seals someone put in are the umbrella type found on Ford V-8's from the 60's and 70's? A positive control type would clamp on the guide itself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2010 at 11:00pm
The seals are umbrella type, like the ones used on a Chevrolet 350 engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2010 at 11:10pm
When you say umbrella type on a Chevy, do you mean the metal "Cap" that is sealed to the valve stem with an O ring?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2010 at 12:10pm
you cut the outside diameter of the guilde down to accept the seal press fit
Edited by mlpankey - 20 Jan 2010 at 12:13pm
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2010 at 12:25pm
You could do it like this fellow did. Two has to be better than one.
Picture 067
Opps it didn't work! Seems it cut off the lubrication and lets the valves run dry.
Picture 068
Chevy didn't design the Allis engines and Allis didn't design the Chevy engines.
If that is where your oil is getting by it could be a short fix but it for sure will not last very long compaired to what little more time it takes in putting gin new guides.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2010 at 1:24pm
sometimes people try anything . Dick youre right chevy and allis is two different designs . Thats why i like reengineering the 226 . I use mopar bronze guides ferra exhaust valves manely intake valves and seals comp springs and titanium retainer super 7 beadlock retainers.aint nothing like 2010 technology or johny cash tunes. its a 51 52 53 57 2000 2001 a piece at a time.
Edited by mlpankey - 20 Jan 2010 at 1:25pm
